Page 1 of 11 1234 ... LastLast
Results 1 to 25 of 260
Like Tree12Likes
    jack murphy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default My Samsung Galaxy S3 won't turn on
    This morning I was on my GS3 and I clicked on a game shortcut (megapolis) and was waiting for it to download, as it was downloading the phone froze and then went off. I haven't been able to turn the phone back on again at all, the phone is not responding to anything I try... is there anything I can do?
  2. #2
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: My Samsung galaxy S3 won't turn on
    Take the battery out for a couple of minutes, put it back and (without turning the phone back on) plug it in to a charger. After a couple of moments you should see the battery graphic, showing the battery charging. Let it charge (regardless of the battery level that it shows) for an hour or so, then try turning it on again and see what happens.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 4
  3. #3
    Camman101's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    it says its charging but nothing is happening with it and it it only like buzzes when i try to turn it on and stuff...Ugh i really need help..i have taken the bat out and all and waited and nothing..It says its charging so ill wait..what do i do if it doesnt turn on?
    Manda Bear1 likes this.
  4. #4
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Camman101,
    Can you try booting into Recovery mode (with the phone completely off, press the Volume Up and Home and Power buttons simultaneously and release them all when you see the splash screen)? If that works you can try clearing the cache and then reboot.
    If the phone just buzzes, can you take the battery out, try turning the phone on, then put the battery back in and try it again.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
  5. #5
    Natallya Avancini's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy Re: My Samsung galaxy S3 won't turn on
    I've tried all of that and yet it still doesn't work. It acts like it's turning on but stays on the same screen as if it were turning on with the 4G and the circle lights around out. I've been trying to take out the battery and leave it out then turn it back on and charge it for a bit while turned off and nothings working. I've been trying everything all day
    faizal aziz likes this.
  6. #6
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Natallya,
    If you tried Recovery mode unsuccessfully then it's time to reload the firmware on your phone.
    You can use the Kies software on your PC to do that. If you need help just let us know.
  7. #7
    meyerweb's Avatar
    Posts
    Global Posts
    10,319 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    have you tried a factory reset from within recovery mode? If not, try that before reloading your ROM.
  8. #8
    Raja Ragoobir's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    my phone is not turning on after i flashed this rom and i cant get into my bootloder can u hel me ?
  9. #9
    josiahlikesminecraft's Avatar
    Posts
    Global Posts
    385 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can you get it into recovery mode or download mode?
    Posted via Samsung S3
  10. #10
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    no i cant please help
  11. #11
    Leidy Fajardo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs down Re: My Samsung galaxy S3 won't turn on
    Hello, My samsung galaxy is not turning on, it did several times and now it wont turned on!
    I put it to charge for about an hour the other day and it worked but it still turned off and came back on again !
    I dont know what to do i bought i new battery cause i thought that was the problem!
    but is not... i erased most of the apps i didnt need cause i thought that could be the problem ...
    Please help ??????
  12. #12
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Raja,
    If we assume that you are familiar with Recovery mode and Download mode and how to get into them correctly, and your phone won't boot into Download mode, then you're SOL. (If you're not really sure how to do that you need to let us know and someone can post a link to the instructions.)
    I saw a guy that advertised JTAG services - that would be about your only option. Sorry.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 2
  13. #13
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Leidy,
    If you take the battery out, wait a couple of minutes and then put it back in, and then plug in the charger, you should see a graphic showing the battery charging. You'll want to wait until it's at least 50% charged before attempting to turn the phone on. You should try booting into Recovery mode and clearing the cache. Then restart the phone and see if it boots normally.
    If it doesn't, you can boot into Recovery mode and perform a Factory Reset and see if that clears up your problem.
  14. #14
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    no could u post the link for sol id i am not familiar with sol
  15. #15
    phreakprincess's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine has the same issue, only two weeks old and one day just randomly shut off and now i cant get it to do anything. It will not charge with or without the battery, I cant even get it to boot into recovery. Any ideas?
    fibrogirl8 likes this.
  16. #16
    meyerweb's Avatar
    Posts
    Global Posts
    10,319 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Raja Ragoobir View Post
    What is "this rom"? And what version of the phone do you have (international, AT&T, etc.)?
  17. #17
    M_S3di021's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i did all of that and it's still not working..any other ideas?
  18. #18
    meyerweb's Avatar
    Posts
    Global Posts
    10,319 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by M_S3di021 View Post
    You did all what? What is your specific problem? Try telling us exactly what is happening, and exactly what you've done, and maybe we can help.
  19. #19
    Crystal Cotterill's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've tried the recovery method and still nothing, my phone hasn't switched on for about 10-15 hours I've attempted to leave the battery out for an hour or so to see if any difference and nothing, I've also tried to charge it more. I've just plugged into my laptop and nothing has happened whatsoever my laptop hasn't even recognised that it is plugged in, any ideas on what to do now?
  20. #20
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Crystal,
    Can you boot into Download mode? (With the phone completely off, press and hold the Volume Down and Home and Power buttons simultaneously, and when you see the splash screen release them all.)
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
  21. #21
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've tried that and nothing, no rep once what so ever. Any other ideas?
  22. #22
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Crystal Cotterill View Post
    I'm not sure what that means - are you saying that nothing comes up on the screen; no LED; no vibration?
    Are you sure the battery is charged? Have you tried a different wall charger AND cable? Do you know someone with an S3 that can charge the battery for you?
    If the battery is fully charged and it won't even power on in Download mode then it's time to take it to your local carrier store.
  23. #23
    michelle sarmiento's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    my s3 froze and i removed the battery but when it won't turn on again, i tried the things that you said
    *Take the battery out for a couple of minutes, put it back and (without turning the phone back on) plug it in to a charger. After a couple of moments you should see the battery graphic, showing the battery charging. Let it charge (regardless of the battery level that it shows) for an hour or so, then try turning it on again and see what happens.
    *Can you try booting into Recovery mode (with the phone completely off, press the Volume Up and Home and Power buttons simultaneously and release them all when you see the splash screen)? If that works you can try clearing the cache and then reboot.
    before but nothing works, please help me.
    nothing comes up on the screen; no LED; no vibration. its just dead
  24. #24
    michele lelah's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have tried pressing th column up and power on button. The phone vibrates and flashes the google logo for a second then nothing.
  25. #25
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by michelle sarmiento View Post
    When the phone is off and you plug the charger in, you don't see the little battery graphic which shows that the phone is charging?
    If not, try this - pull the battery, then plug the charger in, then put the battery back in. Now do you see the battery graphic?
    If neither of those cause the phone to show the charging graphic, try a different charger AND cable. If that doesn't make any difference then a visit to your local carrier store is in order.
  1. Charging Problem - Samsung Galaxy Ace Plus
    By lyndaa54 in forum General Help and How To
    Last Post: 03-23-2016, 08:10 PM
  2. T_T I honestly can say i dislike my DNA
    By kageneko in forum Verizon Droid DNA
    Last Post: 07-23-2013, 07:21 AM
  3. vigin mobile galaxy s3 battery life
    By Russell Eldridge in forum Samsung Galaxy S3
    Last Post: 07-22-2013, 12:16 PM
  4. Waiting for new version for galaxy note
    By alaoddin in forum General News & Discussion
    Last Post: 07-21-2013, 03:57 AM
  5. Can u please relaese ver. 4.3 for galaxy note 1
    By alaoddin in forum Samsung Galaxy Note
    Last Post: 07-21-2013, 03:54 AM
