Galaxy S3 camera problems
kevinbrockett
6
Hello! My name is Kevin Brockett. Just bought a Galaxy S3 from Cricket Wireless and everything works perfectly fine but when I go to use the camera the pictures are blurry and when I take a picture of a object that close like 3-4 inch away the picture is clear but if I want to take a picture of something else like a potrait or somthing mid range to far the picture is blurry like it doesn't want to focus. I tap the screen to try and focuses it and nothing happens. Do you guys think its the hardware or software?
keyzlife
617
Here's a picture of the screen
sent from my T-Mobile Galaxy S?4 with Tapatalk 4
GSDer
8,471
15
You should definitely try another camera app (there's a gazillion of them to choose from) and see what happens. If every other camera app suffers from the same problem then it's probably your camera hardware causing the problem. Just to be sure you'll want to do a Factory Reset (since that's the first thing Customer Service will require) and if that doesn't make any difference then it's time to get it repaired/replaced.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
kevinbrockett
6
When I tap on the screen a white box comes up like it's trying to focus but nothing happens. still a blurry pick. I factory restored the phone too, Auto-Focus On.
LesleyWang
