Smart Launcher + TalkBack fail
nolittdroid
170
4
So I've just started using SmartLauncher which I love...but there is a Smart Launder Notifications plug-in that you activate through Accessiblity settings. When I turned my phone on today, my phone activated TalkBack and I honestly thought my phone was broken for good. I just restarted the phone again to see if I could ping it, and TalkBack turned itself on again. Is there a workaround this? I don't need this useless feature and I don't see how anyone who is blind would benefit from it.
I'm not rooted/rommed and don't want to be. I also don't want to give up my SmartLauncher!
Jennifer Stough
Retired Moderator
Feb 12, 2013
1,971
7
Smart launcher is great, I have the pro, althought I'm not currently using it. Have you tried the recommendation that the dev gives in the description? See screenshot below under "note 2:"
Obscure_Words
Hey,
I hope I still get a reply with the post done a while ago, but I'm having this exact same problem, but I'm following the same steps in the description, but it doesn't seem to be working for. I can't disable the Samsung TTS engine, so I was wondering if there is anything else that I can do? I have a Samsung Galaxy Note 10.1 2014 Edition, and I was wondering if anything you can think of that I can do will help?
Many Thanks
GSDer
8,471
15
Did you go to Settings -> (My device) -> Accessibility and turn off Talkback? (Unfortunately, you'll have to do this every time you restart the phone.)
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
Ashley Austria
can someone help me!!!!!
i dont know how to fix this problem.
my smart launcher notification plug in wont stay permanent. every now and then it works fine but give it a few hours it will stop working so i have to go to preferences and activate the plugin again. getting really tired of having to reactivate it over and over. is there any way for it to stay permanent?
GSDer
8,471
15
Welcome to the forums!
I assume that Smart Launcher: https://forums.androidcentral.com/e...etails?id=com.apofa.saveClicks&token=02vRhpdY is the main app that you're using?
And Smart Launcher Notifications: https://forums.androidcentral.com/e...inlemon.smartlauncher.notifier&token=w5Q1hPOh is the plug-in that you're referring to? Have you tried contacting the developer? gingenzo@gmail.com
FredDev
