Results 1 to 9 of 9
    badelhas's Avatar
    Posts
    Global Posts
    1,500 Global Posts
    Carrier
    Stock 4.1.1 jelly bean
    Default SIM cards not recognized after water incident
    Hi
    After a little swimming in the pool and drying it under the sun all day everything works except sim cards. Can someone who had the same problem advise me on what can I do to try to fix it please? Thanks
  2. #2
    Default Re: SIM cards not recognized after water incident
    1. Try a different SIM
    2. Let the phone dry longer. Common wisdom is to stick it in a sealed container with dry (uncooked) rice and leave it for a couple of days, with the battery removed.
    badelhas's Avatar
    Posts
    Global Posts
    1,500 Global Posts
    Carrier
    Quote Originally Posted by meyerweb View Post
    Thanks but I already tried a dif sim and left it two days under a strong sun (I kive in Portugal).
  4. #4
    Then I'm afraid your phone is toast. Water and electronics don't go well together.
    badelhas's Avatar
    Posts
    Global Posts
    1,500 Global Posts
    Carrier
    I just ordered a SIM/SD Card Reader replacement for the S3 on Amazon for 5 pounds. Its pretty easy to replace it, I hope it works
  6. #6
    Good luck!
    badelhas's Avatar
    Posts
    Global Posts
    1,500 Global Posts
    Carrier
    Good luck!
    Thanks m8. Will try to post when its done. If it does work next step Will be fix the glass, i broke it 2 weeks ago.
  8. #8
    Try cleaning the contacts. Maybe the water caused some oxidation and is keeping it from making good contact.
    badelhas's Avatar
    Posts
    Global Posts
    1,500 Global Posts
    Carrier
    Quote Originally Posted by joneill03 View Post
    Thanks for the tip but Already did that, following a youtube tutorial. But I cant see any oxidation...
  1. Chromecast works as promised, but not as I hoped
    By Doctor Hunt in forum Google Chromecast
    Last Post: 09-09-2013, 08:09 PM
  2. Asus MeMO Pad HD 7 doesn't recognize Sandisk microSD card
    By namsilat in forum ASUS EeePad MeMo
    Last Post: 09-07-2013, 09:10 PM
  3. S3 Screen not functioning - Green Lines/Touch Screen not responding
    By jessicaamber in forum Samsung Galaxy S3 I9300
    Last Post: 09-07-2013, 02:22 AM
  4. Not able update my s3
    By sahilarya92 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-06-2013, 04:53 PM
