1. Bella Hartell's Avatar
    Had the S3 for a while now and never seen this before. The screen requires a single tap, at which time an outline box appears around the app or widget icon, then it requires a double tap to open what ever is selected. Tried to go into settings but without scroll ability, can't do much. Please help! Don't know how or why this happened or how to fix it!
    09-01-2013 11:58 PM
  2. GSDer's Avatar
    Is the phone talking to you when you perform these taps? Sounds alot like TalkBack is enabled.
    If I recall correctly you had to drag two fingers on the screen to navigate. Settings -> Accessibility -> TalkBack.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    Bella Hartell likes this.
    09-02-2013 04:38 AM
  3. meyerweb#CB's Avatar
    See here: Cannot unlock phone (post #6)
    09-02-2013 09:50 AM
  4. Bella Hartell's Avatar
    Thank you so much! I had no idea what talkback is or how it got enabled! Much appreciated!
    09-02-2013 02:33 PM
  5. meyerweb#CB's Avatar
    Talkback is a setting in the Accessibility section of the setup menu.
    09-02-2013 07:14 PM
  6. GSDer's Avatar
    TalkBack often gets turned on when other apps are installed in the Accessibility Services sectionGS3 screen won't scroll and require tap then double tap to do anything! Please help!-uploadfromtaptalk1378179504885.jpgSent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 2
    09-02-2013 10:38 PM
  7. Lori5210's Avatar
    I have a Samsung Galaxy S3 the information screen wont scroll down, I have to tap then double tap on apps I went to settings and it wont scroll !! Is there anyway that I can fix this ?
    07-19-2016 09:30 PM
  8. Rom-er's Avatar
    Did you not read this thread and check the settings they mention?
    Turn off the talk back feature as stated a few posts up. Read before asking because most questions have already been asked and answered somewhere here, that's what the forums are for.
    07-21-2016 07:18 PM
  9. xfoneguy55's Avatar
    I have a different handset but same exact problem - I was getting ready to ship it back to Amazon as I thought it was trashed. Like you, I couldnt navigate "Settings". I finally went back to settings and was able to use the "search" option and typed in (still a pain!) "talkback" - the word popped up a line or two down as a selection. I tapped it a few times and finally got to the "on/off" for it and with much persistence was able to turn it off and VOILA!! It worked - thank you whoever suggested this as the problem - After all was said and done, I remembered inadvertently turning on this "talkback" option. Thank you thank you!!
    08-01-2016 07:09 PM
  1. Assistance needed, please!
    By JS2013 in forum Samsung Galaxy S3
    Last Post: 09-04-2013, 12:35 AM
  2. Transferring pics from PC back to GS4?
    By Mama_00 in forum Samsung Galaxy S4
    Last Post: 09-03-2013, 04:33 AM
  3. Replies: 5
    Last Post: 09-02-2013, 09:55 AM
  4. How to fix unplayable avi videos?
    By Machinist60 in forum Google Nexus 7 (2012) Rooting, ROMs, & Hacks
    Last Post: 09-01-2013, 10:08 PM
  5. Inadvertent save to device
    By Gary Wishik in forum Verizon Galaxy Note 2
    Last Post: 09-01-2013, 08:46 PM
