1. jgawrych's Avatar
    I need to press and hold "9" for 3 seconds to buzz someone in. I have a Samsung Galaxy S3. When I press and hold the "9" key, the tone does not last long enough. I tried pressing multiple times with no success.
    Is there any way to make a cell phone do this?
    Thanks
    09-08-2013 03:43 AM
  2. Chris Miller14's Avatar
    You need nfc enabled door locks but I think the range is quiet short.have a look on the net
    Posted via Android Central App on my s3 GT 19300
    09-08-2013 07:17 AM
  3. Golfdriver97's Avatar
    Thanks
    You may be able to find a dialer app that allows changing the key tone. That is the only thing I can think of.
    09-08-2013 08:42 AM
  4. gozirra's Avatar
    Hit the green Phone icon. Hit the menu button. Call settings. Scroll all the way to the bottom. DTMF Tones (set length of DTMF tones). Tap Long. See if that works?
    If not, here's a free app that plays the DTMF tone for as long as you press the button, sounds like what you need.
    https://play.google.com/store/apps/d....ToneGen&hl=en
    Golfdriver97 likes this.
    09-08-2013 11:00 AM
  1. Totally bricked my phone :( HELP PLZZ
    By zgil86 in forum Droid RAZR MAXX HD
    Last Post: 06-06-2015, 03:10 PM
  2. When Selling how to Wipe but keep Unlocked Bootloader?
    By sudbury78 in forum Samsung Galaxy Note 2
    Last Post: 09-08-2013, 09:21 AM
  3. Anyone think there could be a camera update on the horizon?
    By teddddd in forum Motorola Droid Mini
    Last Post: 09-08-2013, 06:44 AM
  4. how to import themes to xtheme engine?
    By breacherman Williams in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-08-2013, 12:07 AM
  5. My Acer A200 Tablet will not stay connected
    By Angie Mauldin in forum Acer Iconia A200
    Last Post: 09-07-2013, 09:17 PM
