Results 1 to 5 of 5
    Default Will rooting let me silence my camera?
    Right now my camera shutter makes noise no matter what. After rooting, would I be able to silence it? If so, how?
    Also, I'm watching a video right now on what a lot of these terms mean, but if anyone has any other advice, or a link to a basic rooting knowledge thread, I'd appreciate it. I definitely don't want to go into this sort of thing blind.
  2. #2
    Default Re: Will rooting let me silence my camera?
    Yes, it will. What version (Sprint, AT&T, etc.) of the phone do you have? Check out this thread for a few different ways to silence it:
    http://forums.androidcentral.com/spr...2-minutes.html
    This is a good place to start with Android: The Android Dictionary | Android Central . Also see the link in my signature.
    But look at this specifically for info about rooting: Rooting - is it for me? Some Q&A | Android Central
    Lumos likes this.
    I have Sprint. Thank you very much, this is all exactly what I needed!
  4. #4
    Or you can just use Camera ICS: https://play.google.com/store/apps/d...lynx.cameraics and skip all of that rooting stuff.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    Lumos likes this.
    While I was able to make the sound go away with that app (yay), I found I wasn't very fond of the app itself. This is me being picky, but it seems like it would be easier to just edit the file and disable the sound on the app I like (easy after rooting, which I'm still reading into). Thank you for the app! It'll work while I decide.
  1. My Ultra will be here tomorrow
    By Westiemom in forum Motorola Droid Ultra
    Last Post: 09-30-2013, 10:44 AM
  2. help on how to re-root my gs3
    By andgle in forum Verizon Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 09-26-2013, 07:42 PM
  3. Replies: 3
    Last Post: 09-26-2013, 02:24 PM
  4. how do I re-root my gs3
    Last Post: 09-24-2013, 06:00 PM
  5. My One not showing up in device list...
    By SandersJC1964 in forum HTC One M7
    Last Post: 09-24-2013, 07:24 AM
