Hello, I want more power. NOt for daily usage, but for when I know i'm going to be on the phone a lot. For instance, I am planning on running the ROcky 50k, aka 30 mile run in December. I'd like to be able to track the run continuously through Runtastic.
The normal battery will not last the 5-6 hours that I plan on taking.
So, my options are a bigger battery, like a Zero Lemon 7000 mah battery.
Or, an external battery pack, that can charge the phone while I'm running through a micro usb.
I'll be running with a backpack or some kind of belt, so size isn't a huge issue.
Are there any pros/cons to either, in your opinion?
I know that the Zero Lemon will be more portable, no cables, thinner than the phone and battery pack combined, etc. However, it'll ONLY work for my s3. So once I switch phones, which I know I eventually will, it'll basically be of no use. Well, I could let my kids use it, play some games, etc.
The external battery pack might be more practical, in that I can use it to charge many things, etc, but is it worth the extra device to carry?
Will it charge faster than my phone uses power?
Any brands you guys recommend for Battery Packs?
Thanks!
Thanks!
