Results 1 to 11 of 11
    Default Larger battery or external battery pack?
    Hello, I want more power. NOt for daily usage, but for when I know i'm going to be on the phone a lot. For instance, I am planning on running the ROcky 50k, aka 30 mile run in December. I'd like to be able to track the run continuously through Runtastic.
    The normal battery will not last the 5-6 hours that I plan on taking.
    So, my options are a bigger battery, like a Zero Lemon 7000 mah battery.
    Or, an external battery pack, that can charge the phone while I'm running through a micro usb.
    I'll be running with a backpack or some kind of belt, so size isn't a huge issue.
    Are there any pros/cons to either, in your opinion?
    I know that the Zero Lemon will be more portable, no cables, thinner than the phone and battery pack combined, etc. However, it'll ONLY work for my s3. So once I switch phones, which I know I eventually will, it'll basically be of no use. Well, I could let my kids use it, play some games, etc.
    The external battery pack might be more practical, in that I can use it to charge many things, etc, but is it worth the extra device to carry?
    Will it charge faster than my phone uses power?
    Any brands you guys recommend for Battery Packs?
    Thanks!
  2. #2
    Ostrich69's Avatar
    Posts
    ROM
    ACS_ICS_V5
    Default Re: Larger battery or external battery pack?
    Check this out on Amazon:
    Anker® 2nd Gen Astro3 12000mAh External Battery Charger World's-Fastest (4A Output) Triple-Port Shake-to-Wake Highest-Energy-efficiency Backup Power Pack for Google Glass, iPhone 5S, 5C, 5, 4S, iPads, Samsung Galaxy Tablets, other Android Smart Phones and Tablets (Apple adapters and Samsung 30-pin adapter not included)
    http://www.amazon.com/dp/B00CEZBKTO/...idcentral00-20
    thanks, that looks like an awesome battery. seems maybe heavy, but it might be worth it. $10-$15 more than the zero lemon... size worth it? anyone using the zero lemon wishes that they got an external?
  4. #4
    The only real downside to the external battery pack is that it'll be bumping around in your pack and may be subject to coming disconnected from the phone. If you wrap some tape around both the phone and battery pack that should help minimize the likelihood of that happening.
    There should be plenty of juice in the external battery to keep the phone charged, even with the GPS on and a running app tracking your progress. You may want to consider downloading the map ahead of time so that you can turn mobile data off (depending on what the coverage is like on your route).
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    Thanks! Good points. Yeah, I thought about the bouncing part.maybe some kind of Sugru solution to keeping it in place. Although I want to be able to take pics and video, too, so I would need to be able to disconnect it. Hmm... it's an unusual problem to have.
    Sent from my SCH-I535 using Tapatalk 4
  6. #6
    Check this out on amazon :
    RAVPower 14000 mAh External Battery Charger Pack $37.99
  7. #7
    This is very disappointing.
  8. Thread Author  Thread Author    #8
    Quote Originally Posted by lemanskis View Post
    what is?
  9. #9
    Not as disappointing as broken links to attachments.
    Or spam...
    Thanked by:
  10. Thread Author  Thread Author    #10
    Quote Originally Posted by Chen Flynn View Post
    this looks good. the price shows $42.99 now for the 14000. I like that it's a lot smaller than the Anker listed above, however, the output is stronger than this one. Hmm...
    i guess the only thing is is whether i want to deal with the cables.
  11. Thread Author  Thread Author    #11
    i ended up getting this. i'll test this with my running, hopefully it won't be too intrusive. it'll definitely be easier to run with the Zero Lemon, i wouldn't have to deal with the cables. However, in the long run, having a charger that can charge anything will be super helpful.
    it's on sale, too.
    Amazon.com: Mpow® 12000mAh Backup Battery Portable Charger Power Bank for Cell Phone iPhone 5 4S 4 3GS iPad 4 3 2 Mini iPods Samsung S4 S3 Note 2 S2 S1 i9500 i9300 N7100 Nexus 4 Nexus 7 Nexus 10 Sony L36h L39h Blackberry Z10 Nokia Lumia 920 900 HTC O
  1. Galaxy S4 - Which waterproof case? Obex or Lifeproof?
    By planoman in forum Samsung Galaxy S4 Accessories
    Last Post: 04-11-2014, 10:01 PM
  2. Replies: 43
    Last Post: 11-11-2013, 02:55 PM
  3. S3 battery drain, already done 3 factory resets
    By rolo99 in forum Samsung Galaxy S3
    Last Post: 10-09-2013, 11:17 PM
  4. Next bit of kit arrived- note 3 spare battery kit
    By thegame161 in forum Samsung Galaxy Note 3
    Last Post: 10-08-2013, 11:13 AM
  5. Galaxy Note 3 - do you have to turn off note 3 to reset battery stats
    By telinab63 in forum Samsung Galaxy Note 3
    Last Post: 10-08-2013, 11:07 AM
B
