Hello,
I want to find out your opinion about my S3's battery status after i've used it for 4h25m and it reached 61%
I had a problem 2 weeks ago when in the morning i saw that my battery was down with 50% in standby, i did some research and using a wakelock application found that my OS was awaken 1200 times keeping it awake 6h during the night by an application installed 2 days before. I uninstalled it and did also a factory reset. After that it was losing only 15% during night with Wi-Fi on. I use auto for brightness.
Now i think that the battery is not as ok as it was. The phone is 1 month old.
I lose 1% at aprox 4minutes of use with Wi-Fi, if i use Mobile Data it will drain faster like 1% at 2 minutes.
Attached you will see the status of the battery and its usage.
Thanks!
Thanks!
