Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By GSDer
    Patrick oh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Galaxy S3 LTE Stuck Downloading... Do not turn off target!!
    I was attempting to change the firmware of my Galaxy s3 to CarbonRom however at some stage I made a mistake and as a result my phone is stuck on a "Downloading... Do not turn off target!!" screen. It is not in odin mode as there is no writing on the top left of the screen and no matter what i try it keeps returning to this same screen. I have tried flashing back to stock using odin however that is not working as when the phone resets it goes straight back to the same screen. I also can't get into recovery mode, so i can't reset the phone that way. Any help would be greatly appreciated.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,047 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Galaxy S3 LTE Stuck Downloading... Do not turn off target!!
    Quote Originally Posted by Patrick oh View Post
    Welcome to the forums.
    What do you think was your mistake?
  3. #3
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You can try using the Kies software on your PC to reload the stock firmware - here's an overview of what to do:
    - if you don't already have the Kies software installed on your PC, download it (just search Google) and install it. The first time it runs it'll update itself to the latest version so make sure you run it once before proceeding.
    - put your phone in Download mode: with the phone completely off, press and hold the Volume Down and Home and Power buttons simultaneously, and release them all when you see the Samsung splash screen
    - connect the phone to your PC with the USB cable that came with the phone
    -- if you've never had the phone connected to your Windows-based computer before, you'll see messages about installing drivers, etc - just wait until this is done (may take 5 or 10 minutes) [I don't know what happens if you have a Mac - it probably just works]
    - in the Kies software, select the second item in the Tools menu and just follow the prompts to enter the model number (in CAPS) and IMEI/Serial Number (both found under the battery - it's ok to remove the battery at this point)
    - the Kies software should start downloading the correct firmware for your phone from the Internet; once that's done (depending on your Internet connection speed) it'll begin downloading that to the phone (this probably takes 10 minutes or so)
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    Golfdriver97 likes this.
  4. #4
    pvsrnaidu's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi There ,
    need urgent help , i stuck at the same sacreen . Kies coudnt help .
    can u please help.....help.....
  5. #5
    pvsrnaidu's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thank god i managed to rescue my phone
    followed the belwo process.
    How to Unbrick or Restore Samsung Galaxy S3 LTE GT-I9305
  1. Replies: 171
    Last Post: 11-08-2016, 11:47 AM
  2. How do I get my pics to look less pixelated?
    By RiverK in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-03-2013, 01:18 PM
  3. How do I limit internet access on my tablet
    By Marcus Pors in forum ViewSonic
    Last Post: 11-02-2013, 10:14 AM
  4. logo won't come out on galaxy note 2
    By Doron Benkin in forum Samsung Galaxy Note 2
    Last Post: 11-02-2013, 07:37 AM
  5. Maps app in Nexus 7 2013 really having VOICE guided turn by turn navigation?
    By cysuresh in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-02-2013, 05:52 AM
