I charge my S3 mini overnight. 90% of the time it switches itself off during the night. Really annoying when you need the alarm in the morning! How can I stop it from doing this?
Thanks
Thanks
Assuming that you're using an authorized charger and cable, this should never happen. If the Factory Reset doesn't pan out you should take it back to the local carrier store and ask for a replacement - this sounds like a problem with the hardware.90% of the time it switches itself off during the night.
