Results 1 to 9 of 9
    Tdc02's Avatar
    Posts
    Global Posts
    87 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Kies 3 (Samsung S3) & Kies 2.6 (Samsung Galaxy Note 8.0)
    Need help to see how I can keep all my information on both device sync before this update to different Kies. What other apps I can use now for both.
    With AT&T update to 4.3 today on the S3, it also download new Kies 3.0 for the phone only
    My Samsung Galaxy Note 8 have software 4.2.2 and use Kies 2.6
    My S3 have software 4.3 and can only talk to Kies 3.0 and missing the Sync tab like 2.6 had in the above picture.
    razvanbob likes this.
  2. #2
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Kies 3 (Samsung S3) & Kies 2.6 (Samsung Galaxy Note 8.0)
    Quote Originally Posted by Tdc02 View Post
    The Sync tab missing is a known feature change in Kies 3.0.
    If you have two different computers then you can keep the two different versions of Kies, one on each computer. But I don't think you can keep both versions on the same computer (mores the pity).
    You can try
    Cloud Drive: http://market.android.com/details?id...uddrive.photos (automatically backup your pictures/videos to the cloud; 5GB free)
    Helium: http://market.android.com/details?id...ikdutta.backup (allows backup of apps and app data without root; also backup contacts, SMS (but not MMS) and call logs.
    Kies has been the best way to backup MMS and TouchWiz settings, along with pictures/videos.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    Tdc02's Avatar
    Posts
    Global Posts
    87 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    GSDer Thanks alot.
    Another question: I mostly use Kies to keep my contact & calendar in sync with my PC with Microsoft Office.
    Will airdroid 2 work with microsoft office to keep contact & calendar in sync on both phone & table.
  4. #4
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've never heard of AirDroid 2, and AirDroid doesn't appear to have the capability to sync with Outlook.
    You could try mOffice - Outlook sync: https://play.google.com/store/apps/d...ion.isharesync (be aware that their desktop software starts at $15).
    Or there's Outlook.com: https://play.google.com/store/apps/d...ion.isharesync (it has pathetic ratings, but hey - it's from Microsoft - what did you expect?).
  5. #5
    mzkmzk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I downloaded a new Kies 3. It had a sync tab, but couldn't find my Outlook folders. Tried to find someone to help me uninstall 4.3 so I could go back to Kies 2.6 and sync my device (which is very important in scheduling appointments while networking for my startup) but neither my carrier nor Samsung could do it. Samsung already released a fixed Android 4.3 for Galaxy 4 through Kies 3, but as of this morning the Galaxy 3 fix has not been released through Kies 3. So upgrading to the initial 4.3 for Galaxy 3 was a double whammy. We got software that is sucking the lives out of our batteries and causing frequent Wi-Fi disconnects and reconnects, and we lost the ability to sync and back up our phones. Phone upgrade time comes in June. I'll be so relieved to dump this phone!!!
    Quote Originally Posted by GSDer View Post
    You can try
  6. #6
    gbswales's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just come across the same problem the new Galaxy note 3 that I have requires Kies 3 but my Galaxy S3 that I still own will not run using this
    I am not so bothered about syncing but I use Kies 3 to back up my Note but need something to update the firmware on my S3 because I have just restored it using a stock rom that is older than the latest one. Way to go Samsung don't make things backward compatible
  7. #7
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gbswales View Post
    You can have both Kies v3 and Kies v2.6 installed at the same time, and use the appropriate version for each device.
    Your S3 hasn't received an update to 4.3?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
  8. #8
    dave Linforth's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  9. #9
    Sue Lowen's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    how do I download kies 3.0 but keep 2.6 on the same computer. I have 2 phones that use 2.6 and my new phone uses 3.0. The info/data saved in kies 2.6 is important and I don't want to loose it.
  1. ZeroLemon Samsung Galaxy Nexus 5900mAh Extended Battery
    By Lancer033 in forum Verizon Galaxy Nexus
    Last Post: 02-23-2014, 05:10 PM
  2. Go get your $50 play credit from Samsung for your Note 3!
    By buenos in forum Verizon Samsung Galaxy Note 3
    Last Post: 11-23-2013, 09:23 AM
  3. Replies: 1
    Last Post: 11-22-2013, 12:15 AM
  4. Galaxy S3 charging problem
    By maldini3lb in forum General Help and How To
    Last Post: 11-20-2013, 04:57 PM
  5. Low latency audioe with JB 4.2 for Galaxy S2?
    By Randy Freemire in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-20-2013, 03:21 PM
