1. rae2u_112's Avatar
    I have a 'fonts' folder located on sdcard that I use for like UCCW and Zooper. But how do I get android to recognize these fonts? Am I able to move or copy them somewhere so I can use them on my phone?
    11-26-2013 12:19 PM
  2. tat21985's Avatar
    I have the same issue, I think it has something to do with the format that they are in.. I downloaded this> https://play.google.com/store/apps/d....font.pack.fun and I switch my fonts daily using this app, pretty cool..
    GSDer likes this.
    11-26-2013 02:30 PM
  3. rae2u_112's Avatar
    Thanks. I will try it out.
    Sent from my Samsung Galaxy SIII using Tapatalk.
    11-26-2013 05:29 PM
  4. AxlMyk's Avatar
    Do those fonts work for e-mail/texts, especially for other types of phones? Or for documents?
    11-27-2013 01:36 PM
  5. tat21985's Avatar
    All of my daily apps; Tumblr, Words, fantasy sports all change font accordingly, as well as in the settings menu of the phone.. I have noticed there are some apps, however, that do not change font.. Even if it did change within the email app, it's not going to affect your recipient, same with sms.. Basically, all your doing with these fonts, is making the phone more aesthetically pleasing to you..
    11-27-2013 02:42 PM
  6. fryskate's Avatar
    "item not found" <result of your link.. tat
    I'm having trouble as well... even the fonts that the phone shows me in the play store won't work... I've got everything opened up, security wise. it will install and show up within my font list, but once I choose one then a message says it's not compatible/supported, and then asks if I would like to delete said files.... no Bueno...
    running unlocked att gs3 stock
    I'm using Themer if that matters...
    thanks
    12-22-2013 10:35 PM
  7. Upul Premalal's Avatar
    How to install fonts on Samsung Tab with Android OS?
    09-16-2015 10:37 AM
  1. Replies: 1
    Last Post: 06-27-2016, 09:59 PM
  2. Replies: 26
    Last Post: 05-08-2014, 11:00 AM
  3. Nabi 2 or Galaxy Tab 3 for kids ?
    By djjeffa in forum Misc. Android Tablets
    Last Post: 11-26-2013, 11:59 AM
  4. HTC One Google Edition - Error! Update Android 4
    By eesor in forum HTC One Google Edition
    Last Post: 11-26-2013, 11:45 AM
  5. APN used with KitKat
    By Carlos Alberto Mireles in forum Android 4.4 KitKat
    Last Post: 11-26-2013, 10:46 AM
