1. ManvirS's Avatar
    Hello,
    I dropped my galaxy s3 screen hit the surface straight. The screen did not crack however now the display is all black. I can power it on and the sound and everything works and the led flashes and everything. Its just that the screen is all black. If i get a call i can guess the position of the answer key and slide it on the black display and it works. I looked a lot online and now i just need to know do I need to replace the LCD, the Digitizer, or the LCD + Digitizer + Touch Controls? Can someone help and please explain the difference between the Digitizer and LCD?
    12-08-2013 10:14 AM
  2. Paul627g's Avatar
    Sounds like you need to replace the digitizer. Most kits come with both a new glass face and the digitizer screen under near. Since you have to remove both you might as well replace both.
    12-08-2013 11:42 AM
  3. ManvirS's Avatar
    Well there is a big difference because only about $15 for one replacement to $120 to both LCD and Digitizer. Is it difficult to replace just the digitizer? I am Computer Repair certified so i can handle technical work.
    12-08-2013 02:26 PM
  4. GTWalling's Avatar
    Yes it is difficult. The AMOLED Display and Digitizer are glued to each other as well as the Glass screen. Damage may occur to the good trying to take them apart.
    12-08-2013 04:41 PM
  5. ManvirS's Avatar
    Can someone send me a link for the digitizer please? Post it here.
    12-08-2013 04:59 PM
  6. GSDer's Avatar
    There appear to be three layers to the Samsung display assembly:
    - Corning glass (protects everything)
    - digitizer (accepts touch input) [sounds like this is at least partially working on your phone since you can swipe to accept calls]
    - AMOLED display [what people commonly call the LCD] (shows everything you see)
    The digitizer and display must be accurately aligned or you don't end up typing/clicking on what you're seeing.
    It's very difficult to separate the three components without damaging the others, particularly since some of them are glued to each other - for that reason I only make reference to the complete screen assembly, which is the safest, most reliable fix http://m.repairsuniverse.com/samsung...ent-white.html (I'm not in any way associated with this company; this is just one of many suppliers - use whatever resource you like).
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    12-08-2013 07:22 PM
  7. meyerweb#CB's Avatar
    it is NOT the digitizer. The digitizer is touchscreen, and you said that's working. The amoled display is the part not working. But as others have said, it's very difficult to replace just one part. Before you buy anything, though, open te=he phone up and make sure it isn't just a connector that got knocked askew.
    12-08-2013 09:34 PM
  8. ManvirS's Avatar
    I opened the phone and checked the connectors. They are all good. So you guys are saying I should buy the whole set for $120?
    12-08-2013 10:03 PM
  9. tpence2177's Avatar
    I just changed or the glass on my s3a couple weeks ago. It sounds like you need the whole setup. My screen was never black on this one. The glass was just cracked, but I could still see everything behind it.
    Sent from my SCH-I535 using Tapatalk
    12-08-2013 10:18 PM
  10. meyerweb#CB's Avatar
    That's the safest approach. While it is possible to replace onlt the OLED display, the odds of everything working just right afterwards are pretty low.
    12-09-2013 12:58 PM
  11. sofia gomes's Avatar
    Hello!
    I have the same problem as you and I was thinking on buying the whole equipment. Have you tried to fix your phone yet?
    08-22-2014 06:31 AM
  12. GSDer's Avatar
    Hello and welcome to the forums!
    Getting the complete screen assembly is the best way to go. Here are a couple of sources:
    http://www.etradesupply.com/samsung-...-assembly.html
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    08-22-2014 11:28 AM
  13. nosadkhan's Avatar
    hi my samsung s3 neo screen broken are the s3 or s3 neo screen same. Can I replace s3 screen in s3 neo
    10-25-2014 03:22 AM
  14. GSDer's Avatar
    Judging by the specifications for your phone http://m.gsmarena.com/samsung_galaxy_grand_neo-5958.php vs. the S3 http://m.gsmarena.com/samsung_i9300_...s_iii-4238.php the screens aren't even the same size (not to mention a different resolution and pixel density) - sorry, no.
    10-25-2014 01:36 PM
  1. Default storage settings in My Files Galaxy Note 10.1 2014
    By jemsurvey in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-03-2014, 03:42 AM
  2. Samsung Galaxy Note 10.1 (2014) Case Question?
    By joedm126 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 12-10-2013, 11:28 AM
  3. Galaxy S5
    By Photon4glover in forum Samsung Galaxy S5
    Last Post: 12-09-2013, 10:52 PM
  4. Motorola Droid 4 - Cyanogenmod 10.1.3 Help?
    By Violentbacon in forum Motorola Droid 4
    Last Post: 12-08-2013, 10:45 PM
  5. Samsung Galaxy Note 10.1 (2014) Best battery saver?
    By Reuben Skelly in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 12-08-2013, 10:33 AM
