Results 1 to 8 of 8
    Default low memory , cant see device memory in setting
    Hi, I have a samsung s3, the internal memory keeps on getting filled up, i try to check the size of the device by going to settings > storage, however it keeps on saying calculating for each of the tabs e.g applications, pictures, misc and doesnt stop to show to size.... i dont have anything inside my internal memory as i copied to my sd card, im not sure exactly what is eating up my memory?
  2. #2
    Default Re: low memory , cant see device memory in setting
    Try booting into Safe mode and then check the Storage view. We need a starting point for troubleshooting.
    What model/firmware?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    I tried safe mode but no luck it still says calculating after 15min. Model is i9305
  4. #4
    Remove the SD card and see what happens.
    Otherwise, it's time to make a backup and nuke it (Factory Reset).
    I already factor reseted it 3 weeks ago because of this low memory problem thought it would fix everything but didnt wrk....
  6. #6
    Quote Originally Posted by mister1234 View Post
    Did the Storage view work correctly immediately after the reset (before you reloaded your apps through the Google Play Store)?
    This sure sounds like an app problem.
    Yh it did, i think the misc folders are taking up all the memory, but i cant delete because i cant access it through storage view...
  8. #8
    You can try something like DiskUsage: - it'll give you a graphical view of your storage use, allowing you to see the biggest users.Then you can target uninstalling the app(s) responsible.
  1. Problem in street view mode
    By Robodude in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-12-2013, 08:52 AM
  2. No messages in lock screen.
    By UseAndroid86 in forum Verizon Droid DNA
    Last Post: 12-10-2013, 10:39 AM
  3. HELP - deleted music in misc files
    By Katie Akrigg in forum Android Applications
    Last Post: 12-10-2013, 09:37 AM
  4. App comparable to Notes in IOS
    By tech_fan in forum Android Applications
    Last Post: 12-10-2013, 08:36 AM
  5. locate design 4g with android device manager
    By mastaof420 in forum HTC EVO Design 4G
    Last Post: 12-10-2013, 06:39 AM
B
