Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By Golfdriver97
    Default Galaxy S3 Battery Issues * Urgent*
    Losing about 10-15% an hour when the screen is off and I'm not doing anything. This has been happening for about the past week and a half. Phone is also SUPER hot at times, in fact last night it stopped charging because of heat, first time I've ever seen a message pop up like that.
    I already did a factory rest and cleared the cache as well as downloaded JuiceDefender and WakeLock as you can see above.
    My phone was rooted before the reset and I was still having issues.
    Help me please!
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    13,777 Global Posts
    ROM
    Stock Moto X
    Default Re: Galaxy S3 Battery Issues * Urgent*
    Your mobile signal is horrible, that may be a large part of your drain.
    When you cleared the cache, did you do it in recovery?
    Devices: Current: Nexus 5, Moto X, Galaxy Tab 2 (7.0); Retired: Galaxy S2 (Epic 4G Touch); Traded: Galaxy S3
    When I let go of what I am, I become what I might be - Lao Tzu
    Community Guidelines and also here
    Regardless of signal it's still ****, even in airplane mode.
    I did do it in recovery, I think. When you do the reboot screen where you push volume up, home, and power?
  4. #4
    UJ95x's Avatar
    Posts
    Global Posts
    5,528 Global Posts
    ROM
    Slim Kat 4.4.2 Build 3
    Quote Originally Posted by Golfdriver97 View Post
    The mobile signal is that way because of Juice Defender. My battery stats show pretty similar signal, and I have 3-4 bars of LTE.
    Everything in this post is 100% accurate...I think
    R.I.P. Motorola...and what could have been the best smartphone line ever
  5. #5
    UJ95x's Avatar
    Posts
    Global Posts
    5,528 Global Posts
    ROM
    Quote Originally Posted by Neader View Post
    Yes, that is recovery mode.
    From your Wakelock Detector screenshot, it looks like Juice Defender is keeping your phone awake. It's probably hurting the battery more than helping it.
    I turned it off, it being JuiceDefender, and the battery is still draining. Now at 15% since time of the picture. 2% in 8 minutes on airplane.
  7. #7
    UJ95x's Avatar
    Posts
    Global Posts
    5,528 Global Posts
    ROM
    Did you uninstall the app? Try charging it all the way and rebooting. If it was JD, it will go back to normal
  8. #8
    Posts
    Global Posts
    13,777 Global Posts
    ROM
    Stock Moto X
    Quote Originally Posted by UJ95x View Post
    However, a phone will spend exorbitant amounts of power holding onto a weak cell signal which all his screenshots shows he has.
    Be that as it may, how old is the battery? It may be showing it's age and can't hold a charge as well as it used to.
    Thanked by:
    UJ95x
    UJ95x likes this.
  9. #9
    UJ95x's Avatar
    Posts
    Global Posts
    5,528 Global Posts
    ROM
    Default
    2/5 bars is pretty weak, but it wouldn't be enough to drain the battery like this. At least not on it's own...
    Like Golfdriver said, you might need a new battery. After some time, the capacity starts to diminish and probably wouldn't last as long
  10. Thread Author  Thread Author    #10
    I've only had the battery since June.
  11. Thread Author  Thread Author    #11
    Now at 4% even though it's still on airplane, no apps are running, and brightness is all the way down.
    Yay.
  12. #12
    Posts
    Global Posts
    13,777 Global Posts
    ROM
    Stock Moto X
    Yay.
    I would fully charge it and do a factory reset.
  13. Thread Author  Thread Author    #13
    Didn't work :/
  14. #14
    Posts
    Global Posts
    13,777 Global Posts
    ROM
    Stock Moto X
    Didn't work :/
    I would then suggest a new battery.
  15. Thread Author  Thread Author    #15
    I've had it unplugged for an hour and 15 minutes, 77% battery.
    - - - Updated - - -
    Will I be able to get a new battery from Verizon since this once has been screwy even though I rooted my phone?
  16. #16
    Posts
    Global Posts
    13,777 Global Posts
    ROM
    Stock Moto X
    I don't think so. 6 months is probably out of any defect warranty. But it won't hurt to ask.
    From a Sprint Moto X using the AC Forums app.
  17. #17
    The screenshots show that you had it unplugged for 34 minutes.
    And that it was at about 87% charge when you started.
    Did you have it in Airplane mode for most of the 34 minutes? You have a really lousy cellular signal for the remaining time - you might want to try GSam Battery Monitor Pro: (there's also a free version) to better quantify your cellular signal.I doubt that Verizon will give you a new battery, but they may give you a replacement.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
  18. #18
    And just as a follow-up to your original posts and replies - I'm in complete agreement with Golfdriver97 about marginal cellular signal - that can kill a fully charged battery in a few hours: it used to happen to me all the time when I worked in a shielded lab and I finally had to put the phone in Airplane mode whenever I went in to work.
    Also, if you really want proper analysis of battery life (well, the best we can provide in the forums anyway) you need to:
    - start with the phone fully charged - IMPORTANT
    - do not introduce any intermediate charge cycles
    - let the battery run down to 20% or less
    - include all three screenshots (you've been leaving out the Screen Use details) [also include the Radio Detail screenshot if you're using that app]
    Thanked by:
    UJ95x
  19. Thread Author  Thread Author    #19
    I downloaded Grenify and Watchdog LTE and now everything is good!
    Thanks for the help everyone.
  1. Galaxy Gear and the Galaxy S3
    By bboozer in forum Samsung Galaxy Gear
    Last Post: 12-31-2013, 08:28 AM
  2. How to change image viewer on Galaxy Note 3
    By Jerry Jude in forum Samsung Galaxy Note 3
    Last Post: 12-15-2013, 09:27 PM
  3. WTS: Withdrawn
    By Google_Superuser in forum The Marketplace - Buy, Sell & Trade
    Last Post: 12-15-2013, 07:47 PM
  4. Kids case for Galaxy Note 10.1 2014
    By markgoldie in forum Samsung Galaxy Note 10.1
    Last Post: 12-15-2013, 07:31 PM
  5. NFL Pro 2013 issue
    By SuperHans1990 in forum The Gamer's Lounge
    Last Post: 12-15-2013, 07:11 PM
B
