Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By Kevin O'Quinn
  • 1 Post By GSDer
    Default I need help figuring out this icon on my phone.
    I need help figuring out this icon on my phone.-screenshot_2013-12-27-20-59-32-1-1.png
    any idea what it means?
    I could really use some help.
    For some reason i think it could be linked with the fact that i'm not able to access my voice mail at all
    it's a new phone
    Samsung galaxy s3
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    13,801 Global Posts
    ROM
    Stock Moto X
    Default Re: I need help figuring out this icon on my phone.
    Welcome to the forums.
    What happens when you pull the notification shade down? Does it ID the icon?
    Devices: Current: Nexus 5, Moto X, Galaxy Tab 2 (7.0); Retired: Galaxy S2 (Epic 4G Touch); Traded: Galaxy S3
    When I let go of what I am, I become what I might be - Lao Tzu
    Community Guidelines and also here
  3. #3
    Posts
    Global Posts
    13,801 Global Posts
    ROM
    Stock Moto X
    You should also try to get the access fixed to your voicemail. See if that helps.
  4. #4
    Kevin O'Quinn's Avatar
    AC Team Emeritus
    Posts
    Global Posts
    8,897 Global Posts
    ROM
    Stock
    Quote Originally Posted by chavezra View Post
    it's a new phone
    Samsung galaxy s3
    It very well may be linked to that issue. I would start there and then see if the icon goes away. If it doesn't go away after regaining access to your voicemail then post here again and we'll try other things to figure it out. I've personally never seen it on any of my devices. though.
    Kevin F.I.M.T.K. O'Quinn Esq.
    Golfdriver97 likes this.
    Nothing in the drop down area when i click the notification area. I have no idea how to fix my voice mail it doesn't have the blue 'cassette' icon and holding 1 only takes me to save a speed dial
  6. #6
    Posts
    Global Posts
    13,801 Global Posts
    ROM
    Stock Moto X
    It looks like a phone with a line through it, so maybe data roaming?
  7. #7
    AC Team Emeritus
    Posts
    Global Posts
    8,897 Global Posts
    ROM
    Stock
    I would try calling your carrier to get it fixed. They can usually reset it.
  8. #8
    I have the same problem, mine is Galaxy S2 HD LTE
  9. #9
    Haven't seen that icon posted about before. Do you have a 3rd party calling app (ex. Viber, Skype, etc) installed?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
  1. Samasung Galaxy Note 3 Camera - Most of my Pics are Blurry
    By suburbarella in forum Samsung Galaxy Note 3 in Canada (Bell/Rogers/Telus)
    Last Post: 03-10-2014, 08:25 PM
  2. Having Trouble with my 64gb memory card...
    By thebabilonias in forum Verizon Samsung Galaxy S4
    Last Post: 01-16-2014, 07:27 PM
  3. Knox Warranty Void: 1 any want around this?
    By tmp3150 in forum Samsung SAFE and KNOX
    Last Post: 01-06-2014, 09:38 PM
  4. "Android OS" killing my battery...
    By eugchen in forum AT&T Samsung Galaxy Note 3
    Last Post: 12-29-2013, 11:12 PM
  5. Need some help
    By Adrian Rangel in forum Moto X
    Last Post: 12-28-2013, 12:06 AM
B
