Results 1 to 6 of 6
    Default not using wifi, only data
    My galaxy S3 has been using data even when wifi is connected. I tried turning data off and it won't connect to anything. The wifi says it's connected but the phone won't use it. Is there something I can change in the settings?
  2. #2
    Default Re: not using wifi, only data
    I realize that you're new to the forums, but you haven't provided enough information:
    - has it always done this or did it start recently?
    - if the latter, did you just happen to update to 4.3?
    - have you tried other Wi-Fi connections with the same result?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
  3. #3
    Golfdriver97's Avatar
    Posts
    Global Posts
    13,864 Global Posts
    ROM
    Stock Moto X
    -What carrier?
    -Have you turned off mobile data?
    Devices: Current: Nexus 5, Moto X, Galaxy Tab 2 (7.0); Retired: Galaxy S2 (Epic 4G Touch); Traded: Galaxy S3
    When I let go of what I am, I become what I might be - Lao Tzu
    Community Guidelines and also here
    It started about a month ago. I have not updated my phone recently because the phone won't use Wi-Fi. I am on at&t. I tried using other Wi-Fi networks and nothing will work.
  5. #5
    Time to make a backup of your data and then perform a Factory Reset. Skip all of the setup steps (don't even set up your Google account) and test Wi-Fi - if it doesn't work then, it's time to get a replacement.
    The only other suggestion (if you're not going to load 4.3) would be to reload the current firmware using Odin, or see if you can find a flashable zip file with just radios - it's possible that reloading the radios will fix the problem.
  6. #6
    Might just need to reset the router.
  1. Replies: 13
    Last Post: 03-03-2014, 03:46 PM
  2. Galaxy S4 Downgrade M919 4.3 to 4.2.2 Anyway? (not afraid to root)
    By Chris Slatosch in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 01-20-2014, 06:14 PM
  3. phone using data and not wifi
    By benking10 in forum General Help and How To
    Last Post: 12-31-2013, 12:20 AM
  4. samsung galaxy tab 3 cant use apps!!!
    By Kiara O in forum Samsung Galaxy S3
    Last Post: 12-29-2013, 09:39 AM
  5. Replies: 1
    Last Post: 12-28-2013, 11:45 PM
B
