Results 1 to 6 of 6
    Default Google Location Services / battery drain
    I just updated to 4.3 and rooted and now my battery is draining at least twice as fast as before with the same usage. I've read quite a few posts that say that Google Services (specifically location reporting) can cause a lot of issues. Could someone point me to what settings I should tweak?
    Also, if you are aware of anything else that could be causing battery drain after the 4.3 update, please let me know.
    Thanks!
  2. #2
    Foramex's Avatar
    Posts
    Global Posts
    205 Global Posts
    Default Re: Google Location Services / battery drain
    If location services is your issue, then I had that problem too.
    Thing you need to do:
    Settings->location access-> uncheck all the boxes. Try and see if that fixed the issue.
    Proud LG G2 Owner!
    Thanked by:
    I'll let you know if it gets any better. Thanks
    Hm my battery drain has gotten a lot better but i think that's from greenifying and freezing some apps. Especially facebook. I turned location services back on yesterday and it doesn't seem to be doing so bad with them on. Of course I don't enable GPS. Thank you for the tip though!
  5. #5
    Quote Originally Posted by zetodavido View Post
    What a POS... :banghead:
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
  6. #6
    Yeah, FB seems to do background data transfer even if you set it not to. FB wants to know where you are and what you're doing, whether you want to give it that information or not.
    PLEASE, when asking for help provide as much information as possible. We can't help unless we know what the symptoms are and what you did before they began.
    If I've helped you, please click the "Thanks" button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
  1. Droid Mini: Battery Life Since Kit Kat
    By wckesq in forum Motorola Droid Mini
    Last Post: 01-17-2014, 11:54 AM
  2. battey charging battery charging ..... what next !?!?
    By ossamoha in forum Samsung Galaxy Note 3
    Last Post: 12-30-2013, 08:36 AM
  3. Help! I have problems with Google Accounts
    By Hubert Fortier in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-29-2013, 10:09 AM
  4. kit cat makes battery for g2 better?
    By Gavvykinz in forum LG G2
    Last Post: 12-29-2013, 07:13 AM
  5. How can I get my phone not to go in the battery save mode?
    By Taylork64 in forum Samsung Galaxy S4 Active
    Last Post: 12-29-2013, 06:30 AM
B
