Results 1 to 9 of 9
    tkso's Avatar
    Posts
    Default Extended Battery for GS3 not performing to expectations
    Forgive me if this has already been posted before, but I'm extremely frustrated. I have a Samsung Galaxy S3 LTE i9305 running Cynaogenmod CM10.1.3 with yank555 kernel. I have just purchased a 4500 MAH lithium-ion extended battery for my phone and it doesn't seem to be working as it should. Correct me if I'm wrong, but I expected between 12-18 hours of moderate to heavy use with the screen continuously ON, mobile data ON, playing games, music, etc. Instead, what I'm observing is that after 34 minutes, the battery has gone from 100% to 7% with the screen on the whole time reading with Google Books. Bluetooth and GPS and locations services off brightness turned down.
    I should also note that I have the apps Twilight, Dropbox, Facebook, Twitter, Viber, etc running in the background. But I was under the impression that this shouldn't matter and the battery would take MUCH longer to discharge. For example, when I was running stock rom on the Samsung 3000 MAH extended battery, the battery would on average, go down by 10% per hour with CONTINUOUS screen on time and making calls, emails, music, etc, therefore in ten hours the battery would be completely drained. So I expected this THICKER LARGER extended 4500 MAH battery for the S3 would be at almost double that. I should also NOTE that if I leave the device IDLE and do not use the phone at all, it would last very long, but I got the extended battery for continuous use with the screen on.
    I thought maybe the battery is not being indicated properly so I used the Battery Calibration app to try to calibrate the battery so far that doesn't seem to have worked either. Could anyone offer me ideas why an extended battery is not lasting much longer than the stock samsung battery which is only 2100 MAH? The reason I got the extended battery in the first place was because I found the 3000 MAH battery wasn't lasting long enough.
  2. #2
    Haalcyon's Avatar
    Posts
    Global Posts
    6,219 Global Posts
    ROM
    CM 10.2
    Default Re: Extended Battery for GS3 not performing to expectations
    Quote Originally Posted by tkso View Post
    Yeah, something is definitely wrong. Could be a defective battery as I can't imagine how else this could be accomplished.
    Live long and prosper.
    tkso's Avatar
    Posts
    Just an update after observations:
    The phone has been on for 7 hr since it was first discharged from full charge. Screen time has been 5 hr 54 mins and voice calls for 35 min. Currently battery sits at 49% so, going by these figures, phone battery has gone from 100 to 50 in close to 6 hours of screen time (mostly reading an ebook), so you would think that the battery would last 11 hours give or take to fully discharge - I wouldn't be complaining about that. I should note also that the phone has been on WIFI with mobile data disconnected - I don't know if the phone battery would last as long if it was running on mobile data ONLY.
  4. #4
    I guess you're new to the forum so I'll pass on the usual battery spiel. In order to do any kind of battery life analysis we'll need you to post the following two screenshots from Settings -> More -> Battery:(You get the first one by tapping the graph at the top of the main screen.)
    You could also provide a screenshot of the Radio Detail screenin GSam Battery Monitor Pro: (there's also a free version).
    Finally, you should:
    - fully charge the phone before disconnecting it
    - let it drain to 30% or less before capturing the data
    - not perform any intermediate charge cycles
    Edit: since your new battery is twice the capacity I'd expect about twice the performance, all other things being equal. That data was gathered at minimum brightness; mostly on Wi-Fi; good cellular signal; lots of bloatware disabled through Application manager.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    tkso's Avatar
    Posts
    Ok, I managed to get some screenshots. It's certainly not what I would expect. With mobile data connected and WIFI off, 7.5 hours of screen-on time? I was expecting it to be closer to 11 hours.
    Extended Battery for GS3 not performing to expectations-2014-01-04-04.28.39.png
    Extended Battery for GS3 not performing to expectations-2014-01-04-04.28.22.png
    Extended Battery for GS3 not performing to expectations-2014-01-04-04.29.16.png
  6. #6
    Like Haalcyon said its probably defective because that's what i get on my stock battery on moderate to heavy use, and i get double that with my battery pack.
    tkso's Avatar
    Posts
    So you think it's a case of defective battery? Is there any other way that I can wipe the battery stats? The latest CWM recovery does not have the option to wipe battery stats. I'd like to think that the battery level is not being shown accurately, but if it really is a a defective battery I may have to ask for a refund and try another extended battery.
    The extended battery I bought was a generic battery (no brand). Is it normal for these to be defective and not perform as you would expect? Are branded batteries like Hyperion and Gorilla better?
  8. #8
    Quote Originally Posted by Djedgarftw View Post
    You get 7 hours of screen on time with a stock battery? Somehow I doubt that.
    tkso, 7 hours is a LOT of screen on time. The big, bright hi-rez screens on these phones use a lot of juice. 13 hours total with more than half of that screen on is about all you can expect. With a stock battery, 2 - 3 hours of screen on time is all you can expect. I don't think there's anything wrong with your battery at all. About all you can do is turn the brightness down some more. Or buy a 7000 mAh battery.
    Battery stats reset if you charge to 100% and disconnect the charger. That's all.
    PLEASE, when asking for help provide as much information as possible. We can't help unless we know what the symptoms are and what you did before they began.
    If I've helped you, please click the "Thanks" button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
  9. #9
    Quote Originally Posted by meyerweb View Post
    not that hard really i never turn the brightness up and i have all unnecessary things off but its more like 5-6.5 hours
  1. Save data to SD card??
    By ditjuldan in forum General Help and How To
    Last Post: 01-09-2014, 03:18 AM
  2. Is such an app possible for Android? (plz read)
    By Zabrak in forum General News & Discussion
    Last Post: 01-02-2014, 05:01 AM
  3. Guide to Changover from iOS to Android
    By meashish in forum General Help and How To
    Last Post: 01-02-2014, 04:14 AM
B
