Results 1 to 25 of 25
    Paddy1138's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default My Galaxy S3 won't connect to wi fi
    I keep getting a message saying that my internet connection on my home wi fi is too slow. But all other devices are fine like PS3 and laptop so there's nothing wrong with wi fi so it's definitely my phone. Has anyone ever had a problem like this and what can be done to resolve it?
  2. #2
    VidJunky's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: My Galaxy S3 won't connect to wi fi
    You haven't mentioned anything you've done to try and solve this issue, but I would try a couple of things;
    Delete your WiFi connection on your device and set it up again. There may just be something flaky with the setup.
    Download an internet speed test and see what your up and down speeds are. You can get PC versions of these apps also so you could compare your laptop to your device and see if there really is a difference.
    You could reset your WiFi router. Again there could be something flaky with the connection but on the side of the router. Resetting it will refresh your WiFi connections and possibly solve this issue.
    If none of these work or you've tried them post back and we can go from there. Include your router brand also because there may be connection issues with that brand. If so someone has probably figured out a work around or solution.
    Paddy1138's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Cheers so far I've just rebooted the wi fi but will try others when I get home from work. Fingers crossed!!
  4. #4
    ElyasShamaal's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It did not work for me, my galaxy s3 does not even detect wifi while other devices like Nokia and Iphone can detect it and connect to it. Please help me plz.
  5. #5
    Deanig_12's Avatar
    Posts
    Global Posts
    2,445 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ElyasShamaal View Post
    what OS is your s3 running on? if it is 4.3 i had this problem i had to go into recovery and wipe the cache and factory reset my phone 2 times before it began working again :/ try this hope it helps if you need anything just say
  6. #6
    KreepyKen's Avatar
    Just a cool guy
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Unrooted with Nova Prime
    Does your router have WPS? If so, open the wi-fi settings on your phone, tap the menu button (the one to the left of your home button), and select WPS Push Button. You'll get a prompt to then push the WPS button on your router. Push it. Within a half-minute out so, they should pair and they'll remember each other.
  7. #7
    Kathy Larkins's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had this same issue, but it wasn't only at home that it would not connect. Just restarted my phone and it is now working.
  8. #8
    Melissa De Musso's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My wifi won't connect on my S3 mobile but fine with other devices. Was working fine 2 days ago! I have already reset my phone and switched it on and off again and still no luck. It is telling me it's connected but it's not! Help!!!
  9. #9
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Welcome to the forums!
    Quote Originally Posted by Melissa De Musso View Post
    Have you tried rebooting the router? If you don't know how, simply unplug the power for a couple of minutes and then plug it back in and wait a few minutes for the router to finish its boot cycle.
    You could also try 'forgetting' the network and adding it back.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
  10. #10
    Leslie Hopkins's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    this happened to me as well shortly after updating my phone and it sent me a message saying that I needed to enter ##72786# to complete the updates....my phone wouldn't access wifi at all until I did this and afterwards, it worked! Was so frustrating, but worked and no problem since... so I thought it worth posting this....Good luck!
  11. #11
    Clem238's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine did the same thing. Did you get yours working? I cannot find a solution, have tried 30 things. sigh
  12. #12
    Rebecca Wall1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Clem238 View Post
    Hey guys... try going into your router settings under wireless & change your channel... I changed mine from auto to 11 which changed my extension channel to 7 & my phone connected right away good luck...
  13. #13
    Karl Thomas's Avatar
    Posts
    Global Posts
    103 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by VidJunky View Post
    Actually,I have tried delete WiFi connection and set it up again for several times.Nothing changed.
  14. #14
    Rebecca Elliot's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My Samsung Galaxy S3 mini said yesterday morning when I tried to go on my Instagram it said connect to the wifi. So, I slid my page down and I held my my finger on wifi.mwhen it came up it said turning on... . Its been like that since yesterday, I've done everything ven reset my phone remebering to erite down all my contacts. What can I do ?
    Please help me as I am on holiday in German with my Grandparents
  15. #15
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Rebecca Elliot View Post
    Do you mean that you did a Factory Reset on the phone (Settings -> Accounts [if using the Tab view] -> Backup and reset -> Factory data reset)?
    Have you tried turning the phone off completely, taking the battery out for a few minutes and then reinserting it and booting the phone up?
    Did the phone receive any updates around the time this problem started? What about app updates?
  16. #16
    GBPL's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm having this same problem and not finding any solutions thus far... can anyone help with this? Do I have to do a factory reset?
  17. #17
    AxlMyk's Avatar
    Posts
    Global Posts
    1,247 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What have you done so far? I don't mean "everything in this thread", but list the steps you've taken.
    AC App on SGS3
  18. #18
    GBPL's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey AxlMyk... I've done everything I could think of before calling Verizon, and the guy I talked to said that I tried everything that they would of directed me to do..and a factory reset was the only resort. Yes it worked, but I was really not wanting to do that. Now I'm in the process of setting things all back the way I had it. It will take awhile thats for sure!
    I've tried everyones suggestions on this site, to no avail. Hopefully it will never happen again!
  19. #19
    loverain's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sorry AxlMyk...but I did the same thing. Kept happening. Verizon sent me a new phone, had to set it up. Worked great for over a year and now same thing is happening!
  20. #20
    whitedimondwithquestionmark's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can some one please help me? My galaxy 3 wont connect to my home wi fi.
    there is now a white dimond with a ? in the middle of my ssid.
    other devices connect to the wifi and the phone conects to other wifi's.
    I have tryed forgeting the ssid and the phone wont forget it. I have tryed rebooting the phone no luck. I have checked flight mode and cleared the cache,reset the router and wifi, contacted samsung support and my net work provider no luck.
    one day the phone worked and the ssid was normal the next day the ssid had a white dimond with a ? inserted in the gap between the 2 words that are my ssid. when I try to turn on wi fi the phone just keeps serching indefinatly. if I use the forget option the ssid does not dissapeir for my list of wifi.
    my home net net work was hacked and I had to fix all assioiated problems with that event but for some the phone has this lingering problem.
    has any one herd of this?
  21. #21
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by whitedimondwithquestionmark View Post
    Have you tried an SSID composed of just one word?
  22. #22
    vallieb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I installed an app wifi connection manager. That fixed the issue
  23. #23
    Andie49's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    wow I had to register to answer this.. I got home from Mexico.live in Canada and could not connect my phone to the Wifi at home.. I re did my password in my wifi at home and it works now.. just in case this helps anyone..thanks for the help and suggestions on here.
  24. #24
    Toppermk6's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wink Re: My Galaxy S3 won't connect to wi fi
    Blimey.....what a palava to answer in a thread
    I was just going to download the wifi connection app as suggested by someone above me, so I went to play store and it said my download manager was disabled and did I want to re-enable it?
    I said yes, and then it said I would have to restart my phone.............which I did.
    Low and behold..............when my phone restarted my wifi connected?..............how very strange?
    Hope this helps someone
  25. #25
    MaxMan VideoGames's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So here's the problem I got to settimgs, wifi and go to my router. It says wps available but doesn't show the drop box for it, I've connected my tablet and laptop to it so I know wps works. I've tried all ur steps and nothing works plz halp
  1. Google using a lot of my battery recently
    By thegame161 in forum Samsung Galaxy Note 3
    Last Post: 01-13-2014, 12:47 PM
  2. Apps won't install
    By davy4475 in forum Samsung Galaxy S4
    Last Post: 01-13-2014, 10:54 AM
  3. Did i ruin my soft touch casing?
    By knitsewmuch in forum Moto X (2013)
    Last Post: 01-13-2014, 10:32 AM
  4. Samsung Galaxy S3 - Gallery Issues
    By S3Android43 in forum General Help and How To
    Last Post: 01-13-2014, 08:35 AM
  5. HTC One won't install OTA update.
    By rosh88 in forum HTC One M7
    Last Post: 01-13-2014, 08:08 AM
