1. Rahimul Kadir's Avatar
    Hi All,
    I am new to this so please bear with me :-)
    My SGS3 woke me up in the early hours of Sunday morning with it restarting itself repeatedly. The phone turns on, i am able to unlock my screen and probably use the phone for about a minute until it restarts itself again. I have left the phone turned off for many hours and turned it back on again and still the same thing is happening. Also have taken the battery out and left the phone for serveral hours too and even still the problem is there.
    Your help will be much appreciated.
    Thanks - Raf
    01-13-2014 10:51 AM
  2. Jamiela Jadallah's Avatar
    The power/lock screen button might be loose. That is what happened to mine and so my phone kept turning on and off. If you look at the button and it feels loose you might need to get it fixed. Hope that helped. Good luck
    01-14-2014 09:25 PM
  3. Thu Rein Tun's Avatar
    The exactly same problem is happening to me
    The battery is too hot after it happens
    if you know anything please let me know
    06-10-2014 09:52 PM
  4. Thu Rein Tun's Avatar
    For me it is not the button
    If it is the button problem , I think the battery won't get too hot after restarting
    I guess there is no problem with hardware
    I was using gallery while voice recorder running in background
    And it started happening .
    I did the factory data reset but it didn't help.
    Please help if you know anything
    Thanks
    06-10-2014 10:04 PM
  5. GSDer's Avatar
    Welcome to the forums!
    If you take the battery out and reinsert it, does the phone turn itself on?
    If not, if you turn the phone completely off and connect the charger do you see the battery graphic showing the current battery level and charging activity?
    Is the phone hot when it's doing this?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    06-11-2014 01:24 AM
  6. Kita Truth's Avatar
    My phone started shutting off by itself a day ago. After taking the battery out and putting it back in it just started restarting by it self. I left it charged all night and did not cut it on till this evening. I have tried removing and cleaning the area where the power button is that only got the phone to come all the way on then shut off and give me yellow thermometer and the temperature by the battery. plugged up I can get it on and see messages but it still has that note on the screen saying phone unable to charge because battery too low then shuts off after maybe five minutes. What to do??????
    06-12-2014 08:41 PM
  7. GSDer's Avatar
    Does it do this every time you take the battery out and reinsert it?
    It boots up by itself and then shuts down after a couple of minutes and doesn't turn itself on again?
    Was this just once or you're getting a temperature warning every time?
    It's quite possible that your battery IS dead - can you borrow one from someone else? If not you may want to invest in one of the Rav Power 2250mAh batteries.
    06-13-2014 12:25 AM
  8. Kita Truth's Avatar
    My battery is not dead. When the phone does come on it shows my battery is at 41% now. After all the research and trying different things. This just might be a battery issue. I'll try to borrow someone else battery and go to a Sprint Repair store later. I'll let you guys know what the problem is.
    06-13-2014 07:18 AM
  9. Kita Truth's Avatar
    My bad my battery is at 68% and even with someone else's battery it only comes on if its on the charger and still gives me that the low battery temperature message.
    06-13-2014 07:52 AM
  10. GSDer's Avatar
    If you're getting that temperature warning with a different battery then it sounds like your hardware is at fault. You could look at getting it repaired through Samsung or just invest what you'd spend in a replacement - the Moto X is still a great phone for the price.
    06-13-2014 12:27 PM
  1. Replies: 23
    Last Post: 02-02-2014, 01:45 AM
  2. Help with Coby Kryos MID 7125
    By sparker781 in forum Other Tablets
    Last Post: 01-16-2014, 05:40 PM
  3. My tablet has suddenly stopped charging and responding
    By Tezza20 in forum ASUS Transformer Pad TF701
    Last Post: 01-13-2014, 09:54 AM
  4. Help: How to share N7's WiFi over Bluetooth
    By thehyperone in forum Google Nexus 7 Tablet (2012)
    Last Post: 01-13-2014, 09:50 AM
  5. outgoing and incoming is disturbed in Galaxy S3
    By Ad Tabassum in forum T-Mobile Galaxy S III Accessories
    Last Post: 01-13-2014, 09:29 AM
