1. Mr_Lewis's Avatar
    What does it mean when my phone is turned off and gets a complete hundred percent charge. Then when i turn it on still on the charger the phone says it only has 47 percent charge left?
    01-15-2014 07:23 AM
  2. dancing-bass's Avatar
    Chances are the battery circuits need to be re-calibrated.
    Run your battery down until your phone shuts off (do this just before bed), leave it off, and allow it to charge overnight. Power it back on in the morning and it SHOULD be back to normal.
    Do NOT run your battery down until it dies on a regular basis. This is extremely hard on the battery and will shorten its lifespan. If done occasionally (less then once a month) it's fine but if you do it regularly you will eventually have to replace the battery.
    If you notice your battery is already not lasting as long as it used to and you HAVE been running it down until it dies, buy a replacement. Buy a replacement that is directly from Samsung or a reputable manufacturer. Do not just buy the cheapest one off eBay as these are poor quality
    01-15-2014 12:25 PM
  3. Mr_Lewis's Avatar
    thats what i did and it said i had a 100% and i turned it on and it said i only had 47%
    01-15-2014 01:26 PM
  4. Francis S Crocombe's Avatar
    Do you have a custom rom?
    01-19-2014 05:00 AM
  1. Charging Issues Galaxy S III
    By Deante Britton in forum Sprint Galaxy S III
    Last Post: 01-29-2014, 09:27 AM
  2. Broke my Samsung S3 glass twice, please recommend case for S4!
    By Vorbaciov in forum Samsung Galaxy S4 Accessories
    Last Post: 01-24-2014, 11:01 PM
  3. Rooting an S3 Mini
    By Bagman58 in forum Samsung Galaxy S3 Mini
    Last Post: 01-16-2014, 01:07 AM
  4. charging basics
    By bernandops in forum HTC One M7
    Last Post: 01-15-2014, 07:52 PM
  5. Beginners Bluetooth question nexus 4
    By chimpboy74 in forum Google Nexus 4
    Last Post: 01-15-2014, 05:35 AM
