Flashing Light
Feb 10, 2014
Re: Flashing Light - Camera Flash
That strobe feature is part of Samsung`s accessibility feature for hearing impaired. To turn it off:
1. Open Settings.
2. Select Accessibility.
3. Scroll down and find Flash Notification under Hearing.
4. Turn it off. Now strobe notification is turned off. (make sure its not checked)
Pamela Jean
6
There is no such thing as a flash notification to turn off on my Galaxy SIII in Settings, Device, Accessibility. Now what?
GSDer
8,471
15
Depends on the firmware version you're running - it showed up in 4.3.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
Pamela Jean
6
I have 4.3. My page shows:
HEARING
Sound balance
Mono audio
Turn off all sounds
MOBILITY
Press and hold delay
I took a screenshot but don't know how to put here!
GSDer
8,471
15
I wasn't aware that any carriers had removed that setting. If you're having that problem but there's no equivalent setting I'm not sure what to suggest. Factory Reset...
