1. bigredcaddy5's Avatar
    I sometimes send out text messages that I copy and paste from an email, website or another app, using GO SMS Pro. If I type out the text message, and it is 160 characters or less, it gets sent as one text message, as it should. However, if I copy and paste it instead of typing it out, it may split into multiple messages. Again, it's less than the 160-character text message limit. Why does it split it up, and is there a way to prevent this?
    01-20-2014 11:04 AM
  2. srkmagnus's Avatar
    This is the first time I've heard of this issue. Didn't know that copying text and pasting it into the text box would cause it to split if greater than 160 characters, whereas inputing the same amount of text would not. If you are trying a stock messaging App try another from the Play Store and see if the issue continues. It might be related to how the App handles messages, both inputed or copied.
    01-25-2014 10:29 AM
  3. Golfdriver97's Avatar
    I am inclined to agree with magnus.
    01-25-2014 10:31 AM
  4. JudH's Avatar
    Any chance of what you're copying being more than just plain text? Could be the copy and paste is including hidden characters like format codes or even HTML commands. Those extra chars are kicking the length up. I use Chomp and it shows the number of chars in the message before I send it--does your app? If so is it bigger than what's visible?
    Another possible would be your message app is inserting a SIG line like "sent by xyz app" that's bumping the count. Some of the free apps do that until you upgrade to the paid app.
    01-26-2014 09:24 AM
  5. bigredcaddy5's Avatar
    srkmagnus and golfdriver97, I'm already using a non-stock app (GO SMS Pro). Golfdriver97, no sig is being added. My app shows the number of characters before I send, and it's bigger than what's visible...so, if it's putting invisible characters in, how would I delete them if I can't see them?
    01-27-2014 09:12 AM
  6. JudH's Avatar
    First see if GO Sms has a setting that's allowing formatted text and turn it off.
    On way might be to paste into another app that doesn't support anything but text. That would either strip the other stuff or make it visible. Then copy again. I just tried pasting into Office Suite and saved as text only--then reopened. Bit of a hassle. Maybe install a text-only editor?
    01-27-2014 10:18 AM
  7. coastalcarolina's Avatar
    Verizon used to enforce a 160 character limit for text messages and would split them up if it went over this number of characters.
    I'm not sure if they still do this or not, also not sure if other wireless carriers do this.
    01-30-2014 04:04 AM
  8. bigredcaddy5's Avatar
    Thanks, but my concern was with copied and pasted text being split into multiple messages when it is nowhere near the 160 character limit.
    01-30-2014 08:07 AM
  9. GTWalling's Avatar
    I know this does not answer your question, but in GoSMS Pro there is a setting not to split messages over 160 characters. The cut and past could be cause by it adding non seen HTML code, depending where you are copping from. Do not know how to strip out the extra though.
    01-30-2014 07:28 PM
  10. AndroidFanUK's Avatar
    This issue is not specific to Samsung Galaxy S3.
    I experienced it on a different phone but just figured a workaround to solve it.
    Please check my second post on this forum (can't post links yet since under 10 posts)
    AndroidFanUK
    02-23-2015 10:14 AM
  1. Stock email and Drafts
    By Uschiekid in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 07-29-2015, 11:36 AM
  2. files and folders
    By Ruben Tomasov in forum LG Optimus Series
    Last Post: 01-22-2014, 11:24 AM
  3. Manual labor fix? Wrecked both recovery and full mode, Kies no help.
    By GoogleGrease in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 01-20-2014, 04:42 PM
  4. 3.5G modem on Samsung Galaxy Note 10.1
    By djnanuatwork in forum Samsung Galaxy Note 10.1
    Last Post: 01-20-2014, 02:52 PM
  5. issue with VIBER on Galaxy S3
    By soso2565 in forum AT&T Galaxy S III
    Last Post: 01-20-2014, 10:43 AM
