1. digitalfreaknyc's Avatar
    The last two days, I've woken up to a dead battery on my S3.
    I thought it might be a problem with the battery so I switched it out for another back-up that I had.
    Nope.
    Then I thought it was the cable. I've tried several different ones and they all lead to the same result.
    The phone shows that it's charging but it's BARELY charging, if at all. It charged about 10% an hour and that's without my touching or using it at all.
    Is the phone dead? Any ideas that I should try? I was trying to get it to last until the S5 comes out but, at this point, I'm afraid I'm not going to be able to make it. I've never had a problem like this before.
    01-20-2014 03:30 PM
  2. Metchad6628's Avatar
    My s3 did the same thing. Power off the phone and then pull the battery. Leave the battery out for around 15 minutes. Power it back up. My was fine after. Good luck!
    01-20-2014 08:30 PM
  3. meyerweb#CB's Avatar
    You said you tried several different cables, but did you try more than one charger?
    It could also be a defective charging port in the phone, or dirt stuck in the port. See if pushing the connector (gently) to the side, top or bottom and holding it there makes a difference. If you don't have an extra charger, try plugging it into a USB port on a computer (not a USB hub).
    01-21-2014 05:37 PM
  4. Jeffery Lutge's Avatar
    Check the plug in side the bottom mine were bent down i had to bend them back up charges super fast now
    01-22-2014 05:16 AM
  1. SMS with MMS notification
    By evotz in forum Android 4.4 KitKat
    Last Post: 01-25-2014, 10:23 AM
  2. Shut down when charging at night.
    By jefela1 in forum Verizon Samsung Galaxy S4
    Last Post: 01-21-2014, 01:31 PM
  3. Galaxy S3: Problems with apps, files, and the SD card.
    By Forester1 in forum Samsung Galaxy S3
    Last Post: 01-21-2014, 08:53 AM
  4. RF Interference 802.11 Problems
    By Daniel McGrew in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-21-2014, 12:30 AM
