1. kmcdonald22's Avatar
    Hi,
    I have a Samsung Galaxy III mini and I have no problem connecting to wifi except one problem. I have two routers (an inner and outer network) and I have it setup to connect to the one that has the best signal strength. The inner router is in my living room and the outer is in the basement for my computer workshop. The problem I have is that it connects to one of my neighbors unsecure networks even though my outer network is just feet from me. This happens when I step outside most of the time even though I'm just feet away from my outer router. I would like to remove all scanned wifi networks except mine. Is that possible?
    Thanks,
    Ken
    01-24-2014 09:21 AM
  2. Golfdriver97's Avatar
    Hi,
    Thanks,
    Ken
    Welcome to the forums.
    Look for your neighbor's router, and long press it. That should bring up a forget button. Click that.
    01-24-2014 09:33 AM
  3. kmcdonald22's Avatar
    Thanks Golfdriver97,
    The only network that had the option to forget was my neighbors unsecured network. All of the others only have the option to connect. I must have long pressed those and chose forget. I've been walking upstairs and downstairs to see if my phone will automatically switch from my routers and the upstairs router has one bar on the wifi indicator. I guess that's why it's not automatically connecting to my work router even though my work router is at full strength.
    Thanks,
    Ken
    01-24-2014 10:37 AM
  4. Golfdriver97's Avatar
    Thanks,
    Ken
    Is everything working the way you want then?
    From a Sprint Moto X using AC Forums app
    01-24-2014 11:03 AM
  5. meyerweb#CB's Avatar
    To automatically switch routers as you move about an area with multiple ones, try the app Best WiFi. At one of my customer's work sites they have 4 different WiFi routers spread about the space, and this app will switch connections automatically if the one you're on drops below a user-selectable signal strength.
    https://play.google.com/store/apps/d...esign.bestwifi
    Golfdriver97 likes this.
    01-24-2014 11:25 AM
  6. GSDer's Avatar
    I'm no expert, but why don't you (or do you and I'm just misunderstanding?) have one router setup as a repeater? That way there's only one SSID and you just benefit from the extended coverage provided by the second router.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
    01-25-2014 01:01 AM
  7. kmcdonald22's Avatar
    Yes, It is. My phone is automatically switching between my two networks. Thanks for your help, I appreciate it.
    Ken
    01-26-2014 08:07 PM
  8. kmcdonald22's Avatar
    Hi meyerweb,
    Thanks for your response. I added the BestWiFi URL to my favorites folder for future use.
    Thanks,
    Ken
    01-26-2014 08:11 PM
  9. kmcdonald22's Avatar
    Hi GSDer,
    The reason I have two routers is because I work on computers. I have inner and outer networks. A computer connected to the outer network can't see the computers on the inner network.
    Ken
    01-26-2014 08:21 PM
  10. Golfdriver97's Avatar
    Ken
    Glad everything has worked out. See you around the forums!
    01-26-2014 08:46 PM
  1. Replies: 36
    Last Post: 03-03-2014, 08:17 AM
  2. Wifi Popup Notification
    By sitaqui in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-26-2014, 03:08 PM
  3. Moto X: Multiple Bluetooth Connections
    By MHBlink8 in forum Moto X (2013)
    Last Post: 01-26-2014, 01:08 PM
  4. Volume moves down on its own to off
    By Michael Tennessee in forum Samsung Galaxy S4
    Last Post: 01-24-2014, 10:53 AM
  5. Tether Phone to Wifi Tablet to Use Tablet's Wifi Connection at work
    By sethgoldstein in forum General News & Discussion
    Last Post: 01-24-2014, 09:52 AM
