Results 1 to 3 of 3
    drbb917's Avatar
    Posts
    Global Posts
    30 Global Posts
    Default Multiple problems, one question
    Hi everyone,
    I see that I am not the only one experiencing problems after upgrading to 4.3. I've seen many people on all of the carriers complain about this on multiple forums. I have obscene battery drain, wi-fi problems, unstable internet connection, and my phone (Galaxy S3, Verizon) occasionally gets very hot. The heat issue happens usually when the wi-fi symbol in my notification bar has a question mark in it. Despite there being no mention of a solution coming from any carrier or Samsung, I decided to call Verizon anyway, really just to get on record with the heat issue. The tech support supervisor told me they are "aware of the issue" and for now are recommending a factory reset. So I decided I'll give it a try.
    My question is about the 'Backup and reset' feature on the phone. I have 'Back up my data' checked, and it says it will backup my apps, but I believe I've always read that only 3rd party backup apps backup all of the settings for apps, like HD Widgets, Nova Launcher, Poweramp. Can someone tell me if the backup built into my phone will backup all of my app settings, or do I have to get a 3rd party backup app?
    Thank you very much.
  2. #2
    Default Re: Multiple problems, one question
    Your settings and app data are unforutenatly not able to be backed up. The apps themselves will all be backed up, but your data will not.
  3. #3
    OP, go to the Play store and install Helium Backup. It will let you back up pretty much everything.
  1. Verizon: question about global mode
    By Adrian Rangel in forum LG G2
    Last Post: 02-02-2014, 12:12 PM
  2. Probably another one of the most common questions you'll ever get.
    By SpriteFan3 in forum Android 2.3 Gingerbread
    Last Post: 01-28-2014, 09:44 PM
  3. Samsung Galaxy S4: two questions pleasehelppppp!
    By Nav12345 in forum General Help and How To
    Last Post: 01-26-2014, 11:17 PM
  4. Car Charger Problem
    By recDNA in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-26-2014, 01:16 PM
  5. Internet and Connectivity Problems
    By SimonTVesper in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-26-2014, 11:08 AM
