1. Proxboct ViTeA's Avatar
    I recently got a samasung galaxy s3, the problem is that when i press the lock-on button it takes 2-5 seconds for the screen to pop up.
    It takes the same amount of time (2-5 seconds) if i press the home button.
    I've been looking all over the places and couldn't find an answer, maybe some1 can give me some advice.
    01-29-2014 06:28 PM
  2. meyerweb#CB's Avatar
    Have you installed any software on the phone, or did it act this way from brand new, without any third party software? I suspect this is related to an app, but without removing apps one at a time (and maybe rebooting after each one), it could be hard to track down.
    Proxboct ViTeA likes this.
    01-29-2014 08:37 PM
  3. GSDer's Avatar
    You can try booting into Safe mode (http://support.verizonwireless.com/s...ase.html/59242) and see if that solves the problems. If it does, then something that you've installed is causing the problem.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
    01-30-2014 01:10 AM
  4. Proxboct ViTeA's Avatar
    You can try booting into Safe mode (Safe Mode - Samsung Galaxy S® III) and see if that solves the problems. If it does, then something that you've installed is causing the problem.
    in safe mode it seems to pop up the screen much faster...i guess you're right, should be some app that is causing the problem.
    01-30-2014 04:56 AM
  5. GTWalling's Avatar
    You may need to wipe the cache partition, do the following:
    1. Turn off the device.
    2. Press and hold the Volume Up key, Home key, and Power key at the same time.
    3. When the phone vibrates, let go of the buttons.
    4. Press the Volume Down key to move to and highlight wipe cache partition.
    5. Press the Power key to select and wipe the cache partition.
    6. After the wipe is finished, go back up till reboot system now is highlighted and press the Power key to restart the phone.
    01-30-2014 06:55 PM
  1. LG G2 wont stay off
    By badmilk07 in forum T-Mobile LG G2
    Last Post: 01-29-2014, 10:39 PM
  2. Wifi Signal on LG G2
    By Alexander Buff in forum LG G2
    Last Post: 01-29-2014, 06:59 PM
  3. Restore stock lock screen from Go Launcher
    By losl in forum Google Nexus 5
    Last Post: 01-29-2014, 06:53 PM
  4. need for speed mW on nexus 7
    By Del Wright in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-29-2014, 06:05 PM
  5. Streaming Audio Issue - 4.3
    By MaxBuck in forum Verizon Galaxy Note 2
    Last Post: 01-29-2014, 04:56 PM
