1. Nadine Sjuhada's Avatar
    I have some problems here. I dont know since when, but I realized it just now. Almost half of my tracks can not be opened, it says "Sorry, the player does not support this type of audio file." And all these tracks (that cant be opened) are Unknown Artists, even though I have changed them to the correct format everytime I downloaded songs. When I played it on shuffle, it skipped 1 until 5 songs in a row. I use basic music player, musixmatch, and playerpro, but none of them works. I've also checked my playlists and the songs there are gone. I don't understand this, I updated my phone version and apps like in routine but i still got this? And I just moved my songs to 4GB SDCard some other time, is it affecting? Please I need answers. How to get my music back to normal? (My android version right now is 4.3, if that helps).
    ps : Sorry for my english.
    PLEASE ANSWER
    01-30-2014 08:57 PM
  2. UJ95x's Avatar
    PLEASE ANSWER
    Welcome to Android Central
    It's likely that the SD card is corrupted and/or corrupted the music files when you transferred them. Did you have them saved on the internal storage before, or on a computer?
    If you still have copies elsewhere, try placing them directly on the internal storage and see if they work. If they do, you need to format the card and try again
    01-30-2014 09:02 PM
  3. GSDer's Avatar
    Or just leave them in the internal memory and save yourself the hassle of it happening again.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
    01-30-2014 10:58 PM
  4. UJ95x's Avatar
    That works too but I'm assuming that having them on the card is because they don't want it on the phone.
    01-30-2014 11:04 PM
  5. Denisew 1972's Avatar
    Same thing happened to my files while moving from a 16g card to a 32g card. Tried everything to fix it, nothing worked. Thinking it was a corrupt card but never did figure it out. I switched back to the 16g card, use Z Player for the music player and all is well again. I never found out if the card was corrupt or not, didn't want to waste more money buying a new card to try it, but 4g cards aren't that expensive. I'd try a new card and use a computer to transfer files over. Let us know what works, personally I'd like to get a 64g card (my 16g is almost max) and try it out but it's an expensive way to test it just to hope it works LOL.
    02-02-2014 03:25 PM
  1. upload mp3 to google music straight from device ?
    By bagou01 in forum Android 4.4 KitKat
    Last Post: 03-15-2017, 12:13 AM
  2. Storage problems on Sony Xperia S
    By Dawud Beale in forum General Help and How To
    Last Post: 07-03-2014, 04:03 AM
  3. Forum Log In Problems
    By Scott McNeil in forum Samsung Galaxy Tab 2
    Last Post: 01-31-2014, 01:48 PM
  4. Replies: 4
    Last Post: 01-30-2014, 06:49 PM
  5. Problem with Menu screen??
    By africano in forum Samsung Galaxy S4
    Last Post: 01-30-2014, 11:44 AM
