1. mgina283's Avatar
    Hey,
    I've noticed that more and more frequently when I "save to SD card" from dropbox it saves the image as a broken file, most of these files are just simple jpegs and I was wondering if anyone else had this problem or had a way to fix it
    Thanks
    02-07-2014 07:31 PM
  2. prepaidguy9081's Avatar
    Been using dropbox a long time and I have never encountered that issue.
    Try re installing the app.
    Only advice I have.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 4
    02-07-2014 07:33 PM
  3. mgina283's Avatar
    i've just tried that and I can't even uninstall it! I only have the options to Force Stop or Disable...
    I'm going to see if it needs updating
    Nope, no luck with updating
    02-10-2014 05:04 PM
  4. GSDer's Avatar
    You are trying to uninstall it via the Google Play Store?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
    02-10-2014 10:30 PM
  1. Couldn't install on USB storage or SD card
    By peachtree14 in forum Other Tablets
    Last Post: 06-26-2014, 09:54 AM
  2. Multiple user on Nexus5
    By hhshah1979 in forum Google Nexus 5
    Last Post: 02-16-2014, 05:25 PM
  3. App-by-app preferences on pin lock screen
    By justlaxin13 in forum Android 4.4 KitKat
    Last Post: 02-08-2014, 11:06 PM
  4. Having problems with 4.4.2 email app
    By randian in forum General Help and How To
    Last Post: 02-07-2014, 06:02 PM
  5. Moto x contacts problem
    By Bigpgs in forum Android 4.4 KitKat
    Last Post: 02-07-2014, 05:47 PM
