1. Eldon River's Avatar
    Please look at attachments
    I recently bought a Samsung galaxy s3 gt-i9305t second hand from a friend for rather cheap because it was kind of broken, the sim card reader was bork and the screen was kinda weird in a (from what I can tell) quite unique way.
    He said he hadn't dropped it or anything but it just started acting up one day
    What leads me to beleive that this is software is that,
    1. how could somthing like this even be the screen
    2. no visable damage
    3. screen problems show up on screenshots
    4. some times it doesn't even do it (when in camera and while booting up)
    Could someone please help me diagnose and maybe cure this problem
    I've already tried factory resetting it and flashing it from a stock bios i got online (through odin)
    Both times nothing changed.
    So confused please help
    P.S. the phone status says it's modified but the previous owner admitted to never having tampered with it
    P.P.S Screenshot says the problem is occurring in camera too but is not visible on screen
    P.P.P.S the bug seems to flicker all over the place whenever the screen updates
    Attached Thumbnails Samsung galaxy s3 screen problems (probably software)-1939936_10203344470915012_1328643824_n.jpg   Samsung galaxy s3 screen problems (probably software)-1926639_10203344471395024_1257154100_n.jpg   Samsung galaxy s3 screen problems (probably software)-1597134_10203344470394999_1361600664_o.jpg
    02-13-2014 06:58 AM
  2. meyerweb#CB's Avatar
    If you've flashed a complete new ROM via Odin (and you're sure it was the right ROM), and it's still doing this, I'm afraid it sounds like a hardware issue.
    02-13-2014 01:46 PM
  3. GSDer's Avatar
    Perhaps your friend modified it and perhaps he didn't, but the phone status doesn't lie. Your first job is to flash the correct firmware for your model/carrier/region - if we assume that you're in Australia then it should be listed here http://samsung-updates.com/device/?id=GT-I9305T
    You'll want to select the correct carrier, download that firmware and install it using Odin v3.07, perform a Factory Reset and cache wipe and then see what the phone status says.
    Does the phone have the stock Recovery?
    Do you see the problem in both Recovery and Download mode?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
    02-13-2014 05:21 PM
  1. Occasional wifi and mobile data network problems
    By dpbayly in forum Samsung Galaxy Note 3
    Last Post: 02-20-2014, 12:06 PM
  2. Help!!!! My screen resolution is messed up!!
    By sberry11 in forum Samsung Galaxy Note 2
    Last Post: 02-14-2014, 12:05 AM
  3. S3 Gallery Scrolling
    By bulletbrain56 in forum Samsung Galaxy S3
    Last Post: 02-13-2014, 05:47 PM
  4. Replies: 2
    Last Post: 02-13-2014, 05:31 PM
  5. galaxy problem
    By bagasrawala in forum Samsung Galaxy Grand
    Last Post: 02-13-2014, 09:43 AM
