1. Jerry Perez1's Avatar
    I'm with metro pcs and I just got the new update. I changed my wallpaper and when I had to crop the picture it made me chose if I wanted to use gallery or photos and I choose gallery by accident and I was trying to fix it by going to application manager and clear the catcher but I just figured out that I had to go to task manager and clear default anyways I checked the clear default area but the gallery which I had accidentally picked is not there so I don't know what to do so do any of you guys know if there is another way of fixing this and sorry if I'm confusing you.
    02-14-2014 02:33 AM
  2. GSDer's Avatar
    Settings -> More (if using the Tab view) -> Application manager -> scroll right to the ALL tab -> scroll down until you find the Gallery app, then select it and scroll down until you see the 'Clear defaults' button, then select that.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
    02-14-2014 09:24 AM
  1. Please Help with GoLauncher Ex and Google Now
    By Friar Matt in forum Android 4.4 KitKat
    Last Post: 02-02-2015, 03:50 PM
  2. When will 32 GB Galaxy Tab Pro 10.1 be released?
    By MikeSp in forum Samsung Galaxy Tab Pro 10.1
    Last Post: 04-08-2014, 02:09 PM
  3. Nexus 4 major problem please help!!
    By Michael Jarmey in forum Google Nexus 4
    Last Post: 02-17-2014, 09:21 PM
  4. need help s Note app
    By srjaide in forum AT&T Samsung Galaxy Note 3
    Last Post: 02-14-2014, 04:51 AM
  5. Help with N5
    By Vlosaloty in forum Google Nexus 5
    Last Post: 02-13-2014, 11:59 PM
