1. marbletsab's Avatar
    I accidently washed my samsung galaxy s3, and i just found out my s3 was in there when i was taking my clothes to go dry. And when i took the s3 out, opened it, dried it, and placed the phone in rice. After a couple hours i turned the phone back on and the phone turned on, everything works. But the screen keeps flashing, and it's darkened but i can still see the screen and everything and when i turn it off and turn it back on my speaker makes a staticky noise for a while. Does anyone know how long will my phone turn back to normal? or do I have to go get a new one?
    02-17-2014 06:02 PM
  2. Chex313's Avatar
    Turn it off and pull the battery allow it to dry for 24 hours at least.(Including the battery) Using the methods you have been using. Hit it with low setting with a hair dryer if you have to have it sooner. Just wait and let it dry till every nook and cranny has dried.
    You might get lucky...The dryer the better.
    02-17-2014 08:22 PM
  3. marbletsab's Avatar
    How long would i have to blow dry it for cause i tried it for only 5-10 min and it's still the same.
    02-17-2014 09:09 PM
  4. UJ95x's Avatar
    It takes time for the phone to go back to normal. You can't expect it to be perfectly normal in a few minutes when it was in the wash for close to an hour. Leave it in rice for a couple of days with the battery removed. Then see if it has improved
    Sent from my Galaxy S4 running SlimKat 4.4.2
    02-17-2014 09:46 PM
  1. How can I reset my Galaxy S4 without seeing the screen?
    By adngo84 in forum Samsung Galaxy S4
    Last Post: 03-03-2016, 01:55 PM
  2. My review after a few days of use
    By dwd3885 in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 02-21-2014, 02:21 PM
  3. Notification Help Please
    By alanbk1 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-18-2014, 12:17 PM
  4. My phone keeps resetting itself constantly, any ideas?
    By mozzarella72 in forum Motorola Droid MAXX
    Last Post: 02-18-2014, 08:48 AM
  5. Moving to an S3 from a Galaxy Nexus - questions for rooting
    By philosopherisdog in forum Verizon Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 02-18-2014, 12:42 AM
