1. rzinn's Avatar
    I am having battery issues that seem to defy all logic. I have tried everything I can think of. Take a look at these battery curve screen shots - the charge will actually go up when not charging! (among other irregularities:
    Here is a history of what I have tried/experienced:
    - Had about 12 months of good battery life with stock TMO configuration
    - Have had 4 month battle with battery life
    - The battery seems to immediately go to 50% charge right of the charger then have a less dramatic slope.
    - Tried Battery Calibration Aps to reset the BIN file
    - Tried different cables
    - bought 4 new batteries - all have same crazy performance issue
    - Tried wiping cache
    - Tried factory reset 3 times
    - eventually rooted and flashed CM 10.2 - no change!
    - With rooted system and CM installed tried more aggressive monitoring/fixing apps like Greenify, ClockworkMod, Wake Lock Detector, and Root access Battery Calibration Apps.
    - can take the same battery from my wife's identical phone charged to 100% and reads 9% when put in my phone.
    Please help!
    02-18-2014 08:14 AM
  2. GSDer's Avatar
    If the four batteries that you purchased function normally in your wife's phone then it appears that you have a hardware problem - time for a new mainboard.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
    02-18-2014 09:32 AM
  3. rzinn's Avatar
    Thank you GSDer... does that mean "new phone" or is a mainboard something that can be replaced?
    02-18-2014 11:51 AM
  4. GSDer's Avatar
    The mainboard = motherboard in computer terms.
    You may have some luck on eBay, etc, although you need to be sure:
    - it's the same model/carrier as your phone
    - same amount of memory (if that's important)
    - not stolen or a bad ESN (blacklisted by the carrier)
    I haven't done this myself, but I've seen posts from people who have. Of course, given all of the possible problems that you may encounter, it might be cheaper to buy a Moto X, Moto G or Nexus 5 and be done with it.
    rzinn likes this.
    02-18-2014 12:06 PM
  5. rzinn's Avatar
    Ouch!
    Just out of curiosity, why do you recommend those 3? Are they considered comparable to the SG3 or are they a good deal right now or something.
    Thanks again!
    02-18-2014 02:31 PM
  6. GSDer's Avatar
    Moto G = best off contract price for performance if you can live without 4G/LTE
    Moto X = best off contract price for performance if you want 4G/LTE
    Nexus 5 = best off contract price for performance if you want stock Android experience (unless you're on Verizon, in which case you're screwed)
    These are just my opinions based on what I've read; I don't own any of these. YMMV.
    02-18-2014 04:22 PM
  1. Firmware Upgrade Error - Low Battery Error
    By jerky1280 in forum AT&T Galaxy S II
    Last Post: 07-15-2014, 01:01 PM
  2. Low battery alert
    By wardawgmalvicious in forum General Help and How To
    Last Post: 02-18-2014, 06:46 PM
  3. protective battery case
    By whitie iii in forum Samsung Galaxy Mega 6.3
    Last Post: 02-17-2014, 08:36 PM
  4. Battery Life
    By Justin Cardwell in forum Sprint LG G2
    Last Post: 02-17-2014, 06:43 PM
  5. When is Zerolemon releasing a battery for S4 Mini?
    By Shelter7 in forum Samsung Galaxy S4 Mini
    Last Post: 02-17-2014, 01:24 PM
