Results 1 to 6 of 6
    Default portable hotspot problem
    When I try to connect a device to my portable hotspot on my Samsung s3 the device says that there is a authentication problem what's wrong with it?
  2. #2
    Gekko's Avatar
    Banned
    Posts
    Global Posts
    8,236 Global Posts
    Default Re: portable hotspot problem
    your carrier has most likely blocked it because it is a paid optional feature.
    I have data on my phone your portable hotspot just uses your data I used it on my ace 2 but it won't work on the s3
  4. #4
    What carrier and plan do you have?
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
  5. #5
    Most carriers charge extra for mobile hotspot. It's generally not included in the standard data plan.
    But if that's not it, is the hotspot on your phone set up to require a password? If you gave us the exact error message, it might help us diagnose the problem.
  6. #6
    Quote Originally Posted by meyerweb View Post
    Depends on the carrier and plan. But I know that Verizon , att, and tmobile have plans that include hotspot at no additional charge.
  1. Hong Kong 2014 edition 4G Galaxy Note 10.1 registration problem
    By framncru in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 03-23-2015, 10:48 PM
  2. Replies: 1
    Last Post: 04-18-2014, 06:59 AM
  3. play music problem -- throttled 4G ?
    By Rich Franzen in forum Android Apps
    Last Post: 02-24-2014, 10:12 AM
  4. GT-p1000 CyanogenMod Usb Probleme
    By ghostvai in forum Samsung Galaxy Tab
    Last Post: 02-23-2014, 05:53 PM
  5. Note 3: proximity sensor dust problem
    By clevin in forum Samsung Galaxy Note 3
    Last Post: 02-23-2014, 05:46 PM
