Results 1 to 5 of 5
    Unhappy HELP! Not sure which parts are damaged! Whatever the polar opposite of savie is...that's me!
    Ok, so the actual screen (outside part) got cracked (It wasn't shattered or anything, just a couple of long straighter cracks), but the phone was still working perfectly...no freezing, dimming, or anything. Then one day I sat it on my dresser to charge, and when I came back...BLACK! The LED buttons still light up, you can hear the start up sounds, everything else seems to be in perfect working order. So....what happened? What needs replaced? Please help me, I'm technologically challenged (to put it mildly)! Thank you!:
  2. #2
    Default Re: HELP! Not sure which parts are damaged! Whatever the polar opposite of savie is...that's me!
    That doesn't sounds too bad, it just looks like the screen has went. I would take it to a repair shop and get someone to profesionally analyse it, but it sounds to me like you need the screen replaced.
  3. #3
    To add to what Kevin said, the actual screen consists of three parts: the front glass, the digitizer (the touch sensitive part) and the OLED display itself. It's hard to know exactly what happened, but there are two likely possibilities: Either the OLED screen was slightly damaged during the initial break, and that damage gradually got worse (for example, perhaps where the connector attaches to the display was stressed, and has now broken); Or, the cracked glass has allowed the display to flex, causing it to finally break.
    Either way, Kevin is probably correct. A repair shop can replace the entire assembly, and your phone should be good as new.
    PLEASE, when asking for help provide as much information as possible. We can't help unless we know what the symptoms are and what you did before they began.
    LG G3 on Sprint. [Stumped and Bumped, Debloated, Startup apps managed, Trickster, Nova Prime, Swiftkey, G3 Tweakbox]--> Runs smooth as silk, now.
    Thanked by:
  4. #4
    If you're a DIYer here are a couple of sources for replacement screen assemblies:
    http://m.repairsuniverse.com/samsung...ent-white.html
    http://www.etradesupply.com/samsung-...-assembly.html
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
    I appreciate ur input so much...u were a BIG help! Have a great day!
  1. When is kitkat coming to tab 3 10.1?
    By heeemz in forum Samsung Galaxy Tab 3
    Last Post: 09-09-2014, 05:37 PM
  2. need help with new AT&T update
    By transamnut in forum AT&T Galaxy S3
    Last Post: 02-25-2014, 12:26 PM
  3. Was the galaxy s5 prime a myth?
    By HOLLYWOODANT215 in forum Samsung Galaxy S5
    Last Post: 02-25-2014, 02:28 AM
  4. Replies: 0
    Last Post: 02-25-2014, 01:05 AM
