Results 1 to 3 of 3
    Unhappy Samsung Galaxy S3 will not gain/maintain charge
    For the last few days I've been having issues with charging my Samsung Galaxy S3, however today the problem has got worse. The phone will not charge or maintain charge at all.
    When plugged into the AC charger it usually takes several attempts of unplugging/plugging in to get the phone to start gaining charge at all. The phone occasionally charges to a certain point, but then begins to discharge again whilst still plugged in, still discharging itself even when not being used. I've tried switching the phone off completely whilst plugged in and the charge still reduced or charged incredibly slowly. When unplugged from the charger the battery charge depletes extremely fast (around 10% in 5 minutes)
    The phone still shows that it is plugged in and being charged, however the battery charge is constantly dropping no matter what I do, rendering my phone pretty much unusable.
  2. #2
    Default Re: Samsung Galaxy S3 will not gain/maintain charge
    It can be caused two things
    1. micro USB input is damaged, need to be fixed.
    2. USB charging cable can be damaged or loose, try someone else's cable or buy a new
  3. #3
    If the micro-USB port is bad you can try something like http://mobiletechvideos.mybigcommerc...button-repair/ or just go with a wireless charging solution.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
  1. Replies: 17
    Last Post: 07-23-2016, 03:07 PM
  2. Which Galaxy S5 color will you get?
    By deadp1xel in forum Samsung Galaxy S5
    Last Post: 06-26-2015, 10:22 AM
  3. Constant annoyance with uploading and finding music on my Galaxy S3
    By iainhasaface in forum Samsung Galaxy S3
    Last Post: 02-28-2014, 05:21 PM
  4. Replies: 4
    Last Post: 02-25-2014, 07:45 PM
  5. Samsung Updates
    By officialclar in forum Samsung Galaxy Note 3
    Last Post: 02-25-2014, 05:51 PM
