02-11-2017 01:13 PM
31 12
tools
  1. Becka Knaak's Avatar
    No matter how many SD cards I try the phone will not recognize that there is an SD card in it. This is definitely a phone issue.
    1. First, the SD card that came in the phone from Sprint (Samsung 8GB MicroSD class 2), which worked fine for more than a year, became corrupt. The phone showed a message that there was no SD card. I completely turned off the phone and opened it up. The SD card was installed properly. I pulled it out and tried the card in my laptop and my printer and got a media error. The card was corrupt. Ok, just get a new card, right?
    2. I bought two new SD cards - Lexar MicroSD Class 6 - one 16GB and one 8GB. Both are recognized by my laptop and printer - nothing wrong with the cards.
    3. For each card I turned off the phone completely, installed a new card and turned the phone back on.
    4. Then I went to the phone settings > Storage. Under SD card - nothing (see pic). The cards are not recognized. Click image for larger version.
    5. I plugged each of the new cards into my laptop and ran the chkdsk command. Both cards "Windows has checked the file system and found no problems."
    How do I fix the phone? Can I fix the phone?
    02-28-2014 10:20 AM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    What is the card formatted to?
    Depending on the format, the phone may not be able to read the card. Higher class cards use a different format, and that format can obviously read by your PC and printer.
    02-28-2014 10:36 AM
  3. Becka Knaak's Avatar
    IDK. How do I determine that?
    02-28-2014 01:59 PM
  4. Golfdriver97's Avatar
    Insert the card into your PC and right click on it. Then click properties, and that should tell you format type.
    02-28-2014 02:11 PM
  5. Becka Knaak's Avatar
    It turns out the SD card DID just need to be formatted. It was not a phone issue at all.
    I formatted it as NTFS (based on this 3 Ways to Format an SD Card - wikiHow).
    Plugged it back into my phone.
    My phone finally recognized that there was a card in there. However, it said something like "card is blank or has unsupported files".
    I clicked the message and it asked if I wanted to format the card (with warning that it would erase the card). I selected "Format" and now all is peachy!
    Thank you so much for your help!
    02-28-2014 02:28 PM
  6. Golfdriver97's Avatar
    Glad it got sorted out. See you around the forums!
    02-28-2014 04:17 PM
  7. samIOW's Avatar
    Hi,
    Sorry for hijacking the thread,,,, But I have exactly the same problem. I have tried 2 separate 32GB SD cards but none of them are being recognised. I have also tried formatting them both at fat32 still nothing also after reading the he had formatted his as ntfs I tried the same and hoped for response to format , Nothing.. I am not sure what to do, the phone is a Samsung S5 which is only a few weeks old, Is it a phone problem??? any help/advice would be greatly received...
    Thanks
    Sam
    06-28-2014 01:28 PM
  8. GSDer's Avatar
    Welcome to the forums!
    It's not hijacking a thread to post about the same problem - much better than creating a new thread for the same (or similar) issue.
    You didn't say whether or not you were successful in formatting the SD cards as NTFS - did that work properly on the PC?
    Were you able to try the cards in any other devices (Camera; other phone; TV; etc)?
    Do you know anyone else with a smartphone that you could try it on, or to borrow their card and see if it works in your phone?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    06-28-2014 02:08 PM
  9. AxlMyk's Avatar
    Install SDformatter to the PC and use that.
    AC App on SGS3
    07-01-2014 06:27 PM
  10. aj865's Avatar
    AC App on SGS3
    Hi I also have the same problem with my Galaxy S3 not recognising my sd card. It had been working fine up to a month ago and it has just dissappeared from the system. I haven't been able to check this on a computer yet but the fact that its full of music is a little worrying that I have lost data that I haven't backed up. Why would the file system on the sd card change so android couldn't read it. Has this been something to do with the last firmware update. I have had this sd card for five years in many different phones without any problems. Help
    08-14-2014 04:42 AM
  11. GSDer's Avatar
    There have been a few posts about some bug that exists in the Google bug tracker database (laying the blame at Google's feet); I haven't dug that far, so I can't comment on that.
    I never had a problem like this with my previous smartphones but had a problem right out of the gate with my S3 and a SanDisk 64GB card. There was some blame accepted by SanDisk but people continue to have problems, particularly when putting large amounts of music on the SD card, so I'm not sure how far that goes.
    Your best bet is to try formatting that card using https://www.sdcard.org/downloads/formatter_4/ or just ditch it and get another one that you can trust. Be sure you have a backup plan in place in case it happens again.
    08-14-2014 11:42 PM
  12. ThePurpleAndroid's Avatar
    I have tried everything suggested in this thread and I still can not get my father in law's S3 to recognize the SD card. I have formatted it in NTFS, I have used the SD Formatter program suggested. I am having no luck with this issue. If there is any other suggestions, please help me out here.
    08-20-2014 03:43 PM
  13. GSDer's Avatar
    You've tried different SD cards? And they work fine in other phones? If so, sounds like there's a hardware problem with the SD card tray in the phone. http://mobiletechvideos.mybigcommerc...d-tray-repair/ (Note: the SIM card and SD card are both on the same module.)
    08-21-2014 01:46 AM
  14. MNC4mykids's Avatar
    I am having a similar problem. Today, my S3 gave me a message not to remove the microSD card without unmounting (but the card was still in and the back was still on it). I tried restarting but still no microSD card recognized. Then I removed and reinstalled the card again without it being recognized. I took the microSD card out of the phone and tried the microSD card from my tablet and it worked in my phone, so not a problem with the phone hardware. I tried the microSD card from the phone in the tablet and nothing. I tried it in an adapter in my laptop and nothing.
    Any suggestions would be great. I have several recent pic's on this card that I have not backed up yet and do not want to have to resort to re-formatting the card if I can help it but do not have any other ideas how to get these pic's and data off of the card.
    08-23-2014 12:04 PM
  15. Clau Claudius's Avatar
    I've got exactly the same problem and it also happen yesterday.
    The sd from phone can not be recognized anywhere but an other sd is readable by the phone. It is a kingston 16gb with lots of data.
    08-24-2014 04:30 AM
  16. GSDer's Avatar
    Unfortunately this is a somewhat common issue - the S3 corrupts SD cards such that they can't be recognized in the device any longer, and often the SD card is completely unusable afterwards (i.e. can't even be reformatted in the phone or on a computer).
    The only solution is to use another SD card and to take preventative measures - backup the SD card on a regular basis and utilize an app to backup pictures to the cloud.
    08-24-2014 08:38 AM
  17. Clau Claudius's Avatar
    Does any connection between the size or brand of sd and the problem?
    08-24-2014 09:05 AM
  18. GSDer's Avatar
    I'm not aware of any specific data to support that. Early on SanDisk had a load of problems with the S3 and admitted to some problem, and they supposedly redesigned their SD cards, but people continued to have problems (perhaps a fewer number than before? It's hard to quantify data here in the forums).
    I had a 64GB SanDisk high performance SD card (one of the early production line) get totally trashed by the S3. I replaced it with a 32GB Samsung SD card and haven't had it crap out, but I have noticed that when trying to record video to the SD card the Camera app often freezes and locks up the phone, requiring a battery pull and resulting in the loss of the video. If I record the video to the internal memory this problem doesn't occur. YMMV.
    08-24-2014 11:54 AM
  19. Clau Claudius's Avatar
    Thank you so much GSDer!
    One lost question. Any suggestion to recover data from sd?
    08-24-2014 12:39 PM
  20. GSDer's Avatar
    There are services you can drop some bucks on that will try to recover your data (just do a Google search); if I'm not mistaken the common programs that you'd plunk down $50 for that would run on your computer will be useless here since your SD card isn't recognized on the computer - sorry.
    08-24-2014 11:07 PM
  21. Snefie's Avatar
    When I went to Sprint for a similar issue, they told me that the most recent Samsung software updates rendered the SD card that came with it as deprecated. they said the old card was a class 2 and they are already up to class 4. So I just bought an updated card. Would have been nice for them to say something about that, I wouldnt have updated until I moved some things around. Luckily my apps & contacts are on Google and my pics are on Dropbox.
    09-22-2014 12:00 PM
  22. Suj Shah's Avatar
    does that mean you lost the data on the card ?
    11-19-2014 06:03 AM
  23. dmlantow's Avatar
    I found this forum on a google search because I am having a similar issue with a new S3. The difference is that it is saying it cannot find the internal SD card for some apps. I tried to install Copilot GPS but 2 or 3 error messages flashed by to quickly for me to read them then it says Unfortunately, Copilot GPS has stopped. Then I installed Mapfactor Navigator. On initial loading, I got a message saying "Cannot find SDcard". I put in a micro sd card and tried opening again and got the same message. I made sure I could browse the card and open files using ES File Explorer I had saved on it from my old tablet and it read them fine. I then started poking around settings and went into application manager and was able to move Mapfactor to the external sd card and it then worked fine, but moving Copilot did not solve the issue with that app. I have now downloaded Mysword (a bible study app) and on initial launch, it has a screen titled "Select Modules path. The first option is Default data path and when I click OK, I get a message saying "Creation of data path failed". It shows the path it is trying to create is /storage/emulated/0/mysword. I decided to use the option to create my own path and created a mysword folder on my external card and it let me continue on to download the modules, so I decided the problem was with the internal sd card not being writable so I went to the emulated/0 folder to see if I could make it writeable. I checked properties and it showed that it already was so I tried creating a new folder and it would not let me. Any suggestions on how to correct this short of possibly rooting?
    12-16-2014 08:55 AM
  24. jasoncpa's Avatar
    Similar problem. Everything worked fine until I added music to SD card. Process went fine, confirmed files transferred to phone, etc. After unplugging phone from computer, no files were on SD card according to phone. It sees me take the card out and put it it, but gives me a message that card is blank or has unsupported files. Of course, I have the option to format the card, but I can put the card in my computer and see all the files just fine. The card is fine. But, the phone sees it as blank. I see a prior post suggest that the card could now be unusable by the phone regardless of the fact that the computer still sees it just fine. Seems odd, but I suppose the solution is a new SD card? I don't want to buy a new card every time I put new music on it! Any advice would be great. BTW, no data was lost; I do have everything backed up!
    12-25-2014 11:50 PM
  25. papires's Avatar
    Hi.
    I have the exact same problem with my 32GB micro SD. My S3 start complaining and stopped recognizing the card. At first I thought there was a problem with the phone card reader since I can access the card with my PC. But now I discovered that the S3 recognizes other cards. I'm backing uo the card and will try to format it. I still can exchange it with my 32GB camera micro SD but this is a very strange problem indeed. This card worked flawlessly for over 1 year in the phone and still works ok outside my S3.
    01-03-2015 05:17 PM
31 12
  1. samsung s4 ACTIVE kitkat update anyone?
    By AlbertCamus in forum Android 4.4 KitKat
    Last Post: 03-07-2014, 01:54 PM
  2. Galaxy S5 is slightly higher than Note 3 on AnTuTu
    By ChinaOperatingSystem in forum Samsung Galaxy S5
    Last Post: 02-28-2014, 08:07 PM
  3. Websites not viewable on Galaxy S4?
    By 08silveradoonrims in forum Samsung Galaxy S4
    Last Post: 02-28-2014, 09:07 AM
