Samsung Galaxy S3: screen not working
AboTariq_NFC
hi
sorry for my bad English , but my galaxy s3 felt down from approx 3mr high and hit the ground by its corner , so the screen switched off and stay off i tried to restart it and also take the battery out for several minuets but no respond , i can see the notification led light and return light and also setting light , i can also receive calls by tutching in blind on the screen , tutch is working .
so what do you think i should do in this situation
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Re: my samsung s3 screen is off
It is possible that the screen connector got loose, If you feel comfortable, you can disassemble it to check
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
