1. JanP7's Avatar
    I bought my Galaxy S3 1 year and 6 months ago. I started having problems with my normal 2100mah battery. I would charge it but the battery drained faster day after day. So I decided to buy an extended battery, and it brought me to the 4800mah battery. After I charged the battery I started using my phone. I thought the battery wouldn't drain quickly, but it did. It drains quicker than the original 2100mah battery in the begining. Here's my question: is there anyway to check if the battery is in fact 4800mah or if I've just been tricked?
    03-07-2014 11:38 AM
  2. meyerweb#CB's Avatar
    I'm not aware of any simple way to check the battery capacity. But it sounds like you've got something running on your phone which is draining the battery rapidly. We need data to figure out what. Start by charging your phone to 100% and unplugging it. (That resets the battery stats.) Now use it normally until the battery is down below 50%, and take some screen captures of the three screens shown in post #3 of this thread:
    My S3 is draining rapidly, even w.new battery
    Post those screen captures here, so we can try to determine what might be the real cause of the problem.
    03-07-2014 12:40 PM
  3. GSDer's Avatar
    There's an indirect method - run the battery down to about 15%, then turn the phone off completely and connect the stock charger (which provides 1,000mA/h) - it should take about four hours to fully charge the battery (4,800 - 4080 [85%] = 720mA, leaving an ~4,000mA deficit, which should take ~4h @ 1,000mA/h; if you're using a 750mAh charger it should take about 5.4 hours.)
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
    03-08-2014 11:21 PM
  1. trying to recover deleted photos on a sumsang s3 4.3
    By pinkpanther3610 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-12-2014, 05:54 AM
  2. Replies: 3
    Last Post: 03-08-2014, 11:15 AM
  3. Galaxy s4 Contacts
    By kapoorudit in forum Samsung Galaxy S4
    Last Post: 03-07-2014, 10:06 PM
  4. Transfer data in Notes Lite app from Galaxy s3 to Galaxy s4
    By Spiderlady6020 in forum Android Apps
    Last Post: 03-07-2014, 10:36 AM
  5. Transfer data in Notes Lite app from Galaxy s3 to Galaxy s4
    By Spiderlady6020 in forum Samsung Galaxy S4
    Last Post: 03-07-2014, 10:32 AM
