1. Rosieglow181's Avatar
    My phone will no longer sync with Kies. I am trying to upload a film to watch which is in Kies but it won't transfer. Previously this has worked fine. Does anyone have any ideas? I have reinstalled 'My Free Codec' which is the message in the popup, and restarted my computer, but nothing seems to help!
    Thanks!
    03-17-2014 11:27 AM
  2. GSDer's Avatar
    What 'sync' behavior are you referring to? The only sync capability I recall was the ability to sync with Outlook.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    03-18-2014 12:32 AM
  3. dlloyd6565's Avatar
    Are you able to sync your detailed daily calendar from Outlook to your Samsung. I'm having no luck.
    03-31-2014 12:11 PM
  1. [SOLVED] Gmail android problem
    By dougltc in forum Android 4.4 KitKat
    Last Post: 05-14-2014, 10:23 AM
  2. photo vault on Verizon Galaxy S4
    By boos1906 in forum Verizon Samsung Galaxy S4
    Last Post: 03-20-2014, 07:04 AM
  3. My Samsung Galaxy S3
    By dragondraven14 in forum General Help and How To
    Last Post: 03-17-2014, 08:05 PM
  4. HTC ONE: Contacts synced by Facebook not showing up in some apps
    By Marco Ybarz in forum General Help and How To
    Last Post: 03-17-2014, 11:21 AM
  5. Galaxy Tab 7 refuses to turn on.
    By Vetrox in forum Samsung Galaxy Tab 7-inch
    Last Post: 03-17-2014, 10:43 AM
