1. Lachiepower0402's Avatar
    When I try and download on my samsung galaxy s3 4g australia model it does not download on celluar and it displays the blue diagonal flowing lines constantly. But the internet works on celluar as in surfing the web everything works on wifi. I have replaced the phone 2 times and the one I am using is my third. It does the same on two providers vodafone au and optus au. This is ridiculous please help me
    03-18-2014 02:49 AM
  2. GSDer's Avatar
    Strange - if you can surf the Web on mobile data you should be able to download (whatever it is you mean by that).
    You could try Advanced Signal Status http://market.android.com/details?id=com.cc.signalinfo - set it for 3G mode and see if you have any better luck.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    03-18-2014 11:15 AM
  3. meyerweb#CB's Avatar
    What are you trying to download? Does this happen no matter what / where you're trying to download, or is it a specific file / site? If it's something from a website, can you post the URL?
    03-18-2014 03:27 PM
  4. Lachiepower0402's Avatar
    It happens with everything I download including from the internet anywhere and the playstore.
    How do I perform the 3G test with the program quoted above.
    Thank you
    03-18-2014 03:39 PM
  5. meyerweb#CB's Avatar
    Note: I don't have an S4, so the menus may be a little different than what I describe. In Application manager, make sure that the download manager isn't disabled.
    On my S3, with Android 4.3, I'd go to Settings / Application manager. Then go to the Turned Off tab and make sure download manager isn't turned off. If it is, tap it, then tap the Turn On button.
    03-18-2014 03:51 PM
  6. Lachiepower0402's Avatar
    I looked at it and it was enabled so I disabled it and then renabled and then restarted my device and no difference.
    03-18-2014 04:04 PM
  7. Lachiepower0402's Avatar
    Sorry If I should rude but is their anyway in which i can get this fixed because i am going to get a new phone altogether in about 2 months and I will be giving it to someone for a second hand present and I want it to fully work. Thanks for your reply's so far, any help is great.
    03-19-2014 04:43 AM
  8. GSDer's Avatar
    1. In the first screen scroll down and select the 'Additional Info' button
    2. (First time only) In the next screen, read the caution message, check the checkbox and select the 'OK' button
    3. In the next screen, select 'Device information'
    4. In the next screen, scroll down to the drop-down list (its heading is "Set preferred network type')
    - for my Verizon 4G/LTE phone the default value is: LTE/CDMA auto (PRL)
    - if I change the value to: CDMA auto (PRL) then the screen flashes a bit and the Status bar changes to show 3G rather than 4G/LTE
    03-19-2014 11:31 AM
  9. Lachiepower0402's Avatar
    So I put it into CDMA auto (PRL) mode and all I got was was a circle with a cross through it where the signal bars should be and no service, I am guessing this is because this network type is not is Australia or my network does not support it. Is their anything else I can do?
    Regards,
    Lachiepower0402
    03-19-2014 11:52 PM
  10. GSDer's Avatar
    Well, there's a whole list of other choices that you can try in that drop-down list. If none of them allow you to configure the phone in a different network mode then I guess there's something different about the networks in Australia.
    Have you tried booting into Safe mode http://support.verizonwireless.com/s...ase.html/59242 to see what happens?
    Let's forget the Google Play Store issue for the moment (I've been having problems with it for the last month or so) - can you provide a link to something you're trying to download?
    03-20-2014 12:19 AM
  11. Lachiepower0402's Avatar
    I tried going to Safe Mode and trying to download the following pdf file
    https://www.google.com/url?sa=t&sour...kOUetqn7WdlaZA
    Then i got out of Safe Mode and tried all of the network modes in the app and they all allowed me to get internet access but not download except for the the modes: CDMA only and CDMA auto (PRL).
    Is their anything else I can do, because this is getting really frustrating and their is nothing on the internet I can see about people with same problems.
    Regards,
    Lachiepower0402
    03-20-2014 01:37 AM
  12. Lachiepower0402's Avatar
    Hi Again,
    Is their anything else I can do after this since this did not work. If their is nothing you can do, would you be able to refer me to some other website which I can post my problems on so I can get more help.
    Regards,
    Lachiepower0402
    03-21-2014 01:26 AM
  13. GSDer's Avatar
    Just to be clear:
    1. When you click that link you don't see a brief 'Starting download' overlay on the screen?2. You don't see the little down arrow on the far left of the Status bar? (see previous screenshot)
    3. You've used a file manager to look in the default download location and you don't see anything there?I'd normally suggest a Factory Reset, but since you're on your second phone I guess that won't help.
    Have you tried using a different browser? What browser are you using?
    Sorry we've been unable to help - this is really strange. You could try over on XDA - they might have some ideas.
    You haven't enabled any data restrictions or monitoring apps?
    03-21-2014 04:08 AM
  14. Lachiepower0402's Avatar
    When I use the default browser, I click on the link which i gave you and it says starting download and does have the arrow up the top and shows white strip going down. Then when I bring down the notification centre i shows the blue diagonal lines moving right. The title above this is <Untitled> BIG W | The lowest prices you'll find on brands. In the downloads application it shows In Progress and in the default download folder their is nothing about the current download. This is all on cellular, this download works perfectly on wifi on my phone.
    BUT then I tried firefox and it downloaded perfectly on cellular YAY!!!. Then i tried internet and it still did not work.Then I tried the play store and still does not work. What can I do for this and does firefox use more battery.
    Another questions is which is the best network mode to select in the Advanced Signal Status App
    Thank you for all of your help,
    Lachiepower0402
    03-21-2014 06:23 AM
  15. Lachiepower0402's Avatar
    Also can I remove the main internet app and replace with firefox?
    Regards,
    Lachiepower0402
    03-21-2014 06:25 AM
  16. dpham00's Avatar
    Regards,
    Lachiepower0402
    You should be able to install Firefox and set it as the default browser
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    03-21-2014 06:37 AM
  17. GSDer's Avatar
    Are you talking about installing apps or updating apps? If the latter, are you sure that you don't have the Play Store set to only update on Wi-Fi? (With the Play Store open, swipe from the left, select SETTINGS, then see if 'Auto-update apps' is set to 'Auto-update apps over Wi-Fi only')
    Looks like you need to use Firefox; no, it doesn't use appreciably more battery.
    Whichever one gives you the 4G/LTE capability.
    03-21-2014 08:45 PM
  18. Lachiepower0402's Avatar
    It occurs when I download or update applications on the play store.
    03-22-2014 08:18 PM
  1. Samsung Galaxy S4 Active
    By Jawahar Nagarajan in forum Samsung Galaxy S4 Active
    Last Post: 03-24-2014, 10:12 AM
  2. Quick S3 Question
    By Denisew 1972 in forum Sprint Galaxy S III
    Last Post: 03-24-2014, 04:34 AM
  3. LG G2: Problem with the keypad
    By arkin02 in forum LG G2
    Last Post: 03-18-2014, 08:59 AM
  4. Replies: 1
    Last Post: 03-18-2014, 07:47 AM
  5. Samsung Galaxy S4 Active - Region Lock
    Last Post: 03-18-2014, 01:53 AM
