Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By GSDer
    Default My S3 battery drains abnormally quickly
    I just bought my Galaxy S3 a little more than 5 months ago. The battery life has been kinda short from the beginning but I am now faced with a new issue. The battery drains about 1% every other minute and then at the end when its around 10% the screen blurs and then the phone hangs before shutting down. Kindly help me with this problem.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,673 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: My S3 battery drains abnormally quickly
    Quote Originally Posted by Ali Khan15 View Post
    Welcome to the forums.
    I would try clearing cache in recovery first. Here is how: [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.
  3. #3
    Sounds like you have one or more apps running wild. Try booting into Safe mode http://support.verizonwireless.com/s...ase.html/59242 (you won't be able to use any 3rd party apps) and see if the problem goes away. If it does then you know it's some app(s) that you installed. Just a matter of using the right tools to identify the culprit after that.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    Golfdriver97 likes this.
  1. How much should Android system be taking up in battery life?
    By thegame161 in forum Samsung Galaxy Note 3
    Last Post: 03-25-2014, 02:57 PM
  2. Battery Draining
    By steph_wilkes73 in forum Verizon Samsung Galaxy S4
    Last Post: 03-25-2014, 11:48 AM
  3. Is Google + backup a battery killer?
    By Sonnydigs in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-24-2014, 09:26 PM
  4. Having problems charging your Galaxy S3 CHARGING SOLUTION
    By Tom Caddick in forum Samsung Galaxy S3 I9300
    Last Post: 03-24-2014, 12:59 PM
  5. Connecting two bluetooth headphones to S3 at the same time
    By mpadhu in forum Samsung Galaxy S3
    Last Post: 03-24-2014, 12:22 PM
