Results 1 to 14 of 14
Like Tree13Likes
  • 1 Post By B. Diddy
  • 1 Post By Patrick Schroedl
  • 2 Post By Carlo Villa
  • 1 Post By mrsmumbles
  • 2 Post By GSDer
  • 2 Post By AxlMyk
  • 3 Post By B. Diddy
  • 1 Post By GSDer
  • 1 Post By DroidRooter
  • 1 Post By msndrstood
  • 1 Post By Spencerdl
    Unhappy Urine Damaged S3, Help?
    So one night a couple months ago, I got a pretty drunk and ended up peeing my bed. The worse part about it though was I still had my jeans on with my S3 in my pocket. When I woke up the next morning I started to panic and instead of putting the phone in rice, I dried the battery and the empty back with a paper towel and plugged it into the charger to see if the phone still worked. To my surprise the phone did turn on, and after a couple hours charging it seemed to be working normally. I thought maybe I got lucky and avoided damage because the phone was dead before it got wet.
    However, a few days later I started to notice a few things that I believe could be a result of the "water" damage.
    1. 4G is unreliable. In areas where it shows 4G service, I sometimes cant connect to the internet. Other times it doesn't even show that I have 4G service, even though I used to get it in those areas.
    2. Calling on my phone is unreliable. This is a similar to the 4G problem, it shows I have service but when I try to place a call it never rings. It makes no sound until after a while it makes the disconnect sound. It also doesn't always tell me that I have an incoming call. There have been several instances where my friends told me they have been trying to call me but I don't pick up. So apparently they can hear my phone ringing, but my phone doesn't.
    3. Texting is unreliable. Again, similar to the 4G and calling problem. In places where I have signal, I cant send or receive text messages. I could send one text fine with no problem, and then try to send another text a few minutes later, and it says sending with the little spiral until it gives up and says couldn't send message.
    4. Battery drains a lot faster. The battery used to last me a full day, but now it lasts maybe 3/4 or 2/3 of the day.
    Both water damage indicators, on the battery and on the inside where the battery goes, are red. So obviously the battery has been affected by the "water". My question to you all is, could I just replace the battery or SIM card? Do I have to replace a part inside? Or is my phone screwed, and I need to get a new one? Any input would be greatly appreciated.
    TL;DR: Pissed my pants with my phone in pocket; calling, 4g, and texting haven't been working reliably ever since
  2. #2
    Default Re: Urine Damaged S3, Help?
    Welcome to Android Central, and yikes! From what I've read about phones getting wet, it's probably more complicated than just replacing the battery or a simple part. The damage is probably done.
  3. #3
    Patrick Schroedl's Avatar
    Retired Moderator
    Posts
    Global Posts
    3,828 Global Posts
    Quote Originally Posted by B. Diddy View Post
    This. Any damage resulting from water exposure is probably outside of your control. The one caveat is if you can identify the affected part and feel comfortable installing a replacement part yourself. Even then, it's no guarantee. Water exposure can do funny things, and connectivity and audio (microphone, speaker) issues are plausible.
    If you can't find any visible signs of damage in the battery compartment or SIM tray, there may be no easy way to tell.
    B. Diddy likes this.
  4. #4
    Lesson learned I hope. .. Don't drink and pee in your bed
    Sent from my SM-N900V using Tapatalk
    ufcfan72 and Amir like this.
  5. #5
    An alternate possibility is that your network started to get bad the same night you got drunk. All those problems, except for the water damage indicators, could easily also be the result of network problems. Probably not the case, but just thought I'd throw it out there. :-)
    Sent from my Nexus 5 using Tapatalk 2
  6. #6
    Retired Moderator
    Posts
    Global Posts
    3,828 Global Posts
    Quote Originally Posted by mrsmumbles View Post
    Also this. It can be easy to attribute unrelated phone behavior to recent damage/water/whatever if you're already looking for anything not "normal" with your phone. I'd say that the data and call symptoms and increased power usage are plausible effects in this case, though. My first step would definitely be to replace the SIM card and make sure the SIM tray and slot are clean and free of damage.
    mrsmumbles likes this.
  7. #7
    Urine is pretty acidic which can be quite bad on electronics. Oddly enough, the best thing for it would probably be a bath - isopropyl alcohol would be the thing to use. Obviously the phone would need to be completely dismantled, and you'd probably want to use something like a toothbrush to scrub any residue off the parts, then put all the parts in rice for 24 hours. (One of the nice things about isopropyl alcohol is that it evaporates quickly.)
    Or you could look for any electronics cleaner.
    Of course, you'll have to be careful around the screen - you don't want to soak that. And I'd rinse the battery in water rather than using alcohol on it.
    YMMV.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
  8. #8
    Never, under any circumstances, take a laxative and sleeping pill on the same night.
    Pissing is mild when compared to the outcome of that.
    Sent from my SCH-I535 using Tapatalk
    ufcfan72 and DroidRooter like this.
  9. #9
    Wow. I learn something new every day on this forum!
  10. #10
    I don't even want to inquire about WHICH new thing you're referring to
  11. #11
    *snip*
    Quote Originally Posted by Patrick Schroedl View Post
    *snip*
    Quote Originally Posted by dskwirut23 View Post
    *snip
    The other part that could've played its card is the fact that urine has (however small) corrosive acidity in it. Depending on how much you urinated, it can be more corrosive in higher volumes.
    Sent from my XT1032 using Tapatalk
  12. #12
    Quote Originally Posted by AxlMyk View Post
    Agreed.
  13. #13
    msndrstood's Avatar
    Posts
    Carrier
    Stock JB 4.1.2
    Inquiring minds want to know... Does it smell? Sorry. Had to go there.
    Sent via The Big, Bad, Beautiful Note 3
    Spencerdl likes this.
  14. #14
    Quote Originally Posted by msndrstood View Post
    LOL...I was thinking the same thing....LMAO!!!
    msndrstood likes this.
  1. Replies: 2
    Last Post: 03-31-2014, 06:15 AM
  2. Replies: 2
    Last Post: 03-26-2014, 05:44 PM
  3. Expandable notification not working...help please!!
    By meniki2009 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-25-2014, 12:41 AM
  4. Case Problems Help
    By sonic1519 in forum Samsung Galaxy Note 3
    Last Post: 03-25-2014, 12:26 AM
  5. FM on S3
    By Manoj Sanghavi in forum AT&T Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 03-24-2014, 06:13 PM
