1. saab61's Avatar
    hey guys
    i have an unrooted samsung galaxy s3 android 4.3
    i have just hard reseted my phone and did a factory reset
    i am looking for a setup to save the most battery possible.
    i dont care if i have no connection and recieve no messages. i just want to save as much battery possible no matter wh
    do you guys know any tips, tricks, setups, settings or battery saving apps that really works?
    tell me what you guys are doing to save the most battery possible or wich settings and apps you are using!
    tank you very much!
    03-29-2014 06:04 PM
  2. GSDer's Avatar
    You could start with S3 Tips, Tricks, Battery Life (Everything you wanted to know about your Galaxy S3)
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    03-30-2014 04:11 PM
  3. meyerweb's Avatar
    If you really don't care about being, essentially, offline, you can turn off wifi and mobile data. You might also check out the Greenify app in the play store. I think it's the one battery saving app that does more good than harm, if you configure it right.
    03-30-2014 04:22 PM
  4. GSDer's Avatar
    Greenify: https://play.google.com/store/apps/d...sfeng.greenify used to require root but it looks like the latest version supports unrooted phones (although I'm not sure what limitations that presents, if any).
    03-30-2014 09:24 PM
  5. meyerweb's Avatar
    The biggest limitation is that on a non-rooted phone Greenify won't put apps to "sleep" automatically when you turn the screen off. Instead, you need to put a widget on your home screen and tap it to put all the apps you've specified to "sleep." A little bit of an annoyance, but it probably becomes habit pretty quickly.
    GSDer likes this.
    04-01-2014 09:51 AM
  1. LG G2: Constant Battery Drain?!
    By AKFL3TCH3R in forum Verizon LG G2
    Last Post: 04-12-2014, 09:46 PM
  2. ZeroLemon 7500mAh battery not being recognized/charging
    By Corey Copp in forum Samsung Galaxy S4 Accessories
    Last Post: 04-05-2014, 05:26 AM
  3. Google+ doing insane battery drain?
    By JnEricsonx in forum Android Apps
    Last Post: 03-29-2014, 06:18 PM
  4. ZeroLemon 7500mAh battery not being recognized/charging
    By Corey Copp in forum Chargers and Batteries
    Last Post: 03-29-2014, 01:25 PM
