Results 1 to 3 of 3
    Default Unstable Network Connection on SGH-I747M
    Can somebody please help me resolve this issue? After the upgrade to 4.3, I encountered wi-fi connectivity issue. I can connect to the wifi at home but after some time, a message pops in my notification bar that says " your internet connection is unstable". Though my connected to the wifi at home, I can't connect to the internet. I've read in some forums to do the following:
    1. Forget network then add it again
    2. Wipe cache partition
    3. Uncheck the 3 boxes in your settings>location services
    4. Restart/reboot the router
    5. Make sure the date and time are correct
    6. Back up data and do a factory reset.
    I did all of them but nothing worked. Is there anything else that I can do? Please help... This is becoming so frustrating(
  2. #2
    Default Re: Unstable Network Connection on SGH-I747M
    Welcome to Android Central, and thanks for listing what you've tried so far--it makes it much easier for us to answer! Look for the Advanced Wi-Fi Settings--is there a setting to avoid weak networks? If so, uncheck it. Also, if there's an option for "Wi-Fi Optimization," turn it off. On my Nexus 5, that is more for battery optimization, not improved wi-fi performance.
  3. #3
    The usual recommendation is to select the checkbox in that pop-up that let's you ignore it in the future - it's just a useless warning.
    However, you're saying that you get a connection to the router (you get an IP address?) but you don't have Internet access - is that correct?
    How many curved bars do you get in the Wi-Fi icon?
    Have you tried connecting via Wi-Fi somewhere else?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
  1. Replies: 3
    Last Post: 04-06-2014, 07:38 PM
  2. Is better Google Drive integration on Android coming?
    By Niklas W in forum Android Apps
    Last Post: 03-29-2014, 08:33 PM
  3. Phone hit floor, problem turning back on
    By cordless_cellphone in forum T-Mobile Galaxy S II
    Last Post: 03-29-2014, 08:10 PM
  4. How to get offline speech to text on ics
    By ahawkua in forum Android 4.0 Ice Cream Sandwich
    Last Post: 03-29-2014, 07:15 PM
  5. i can't turn on the wifi on my s4
    By Naeem Zahid in forum Samsung Galaxy S4
    Last Post: 03-29-2014, 05:41 PM
