1. tigerpierre's Avatar
    I understand that performing a battery pull can help clear somewhere issues that may have clogged a phone. Here's my stupid question for the day - Do pull the battery with the phone on or off??
    03-30-2014 04:28 PM
  2. Gbuch's Avatar
    That only helps on iphones.
    [EDIT] But on a more serious tone, you probably should NOT pull the battery off the phone while it is on. Same for any electronic device. You could corrupt data, or some more serious damage.
    Apart from that, I don't know what pulling the battery off could help...
    [EDIT 2] Doing a bit of research: (1) of course, you might need to do a battery pull if the phone seems hanged on some task for a while and nothing responds. But that's an emergency scenario, and (2) it seems blackberrys needed battery pulls because the phones didn't turn off completely through the off button; I'm not aware that Android requires the same.
    tigerpierre likes this.
    03-30-2014 04:34 PM
  3. Spencerdl's Avatar
    Do a Battery Pull when the phone completely shuts down
    03-30-2014 04:40 PM
  1. Camera Flash with Low Battery
    By mikefish96 in forum HTC One M8
    Last Post: 06-03-2016, 04:52 AM
  2. Replies: 4
    Last Post: 09-15-2014, 12:22 AM
  3. Battery Drain After Firmware Update on Galaxy S4
    By dave2828 in forum Samsung Galaxy S4 Google Edition
    Last Post: 07-29-2014, 10:12 AM
  4. Galaxy S3: Battery nearly dead in three hours!
    By jlehrer100 in forum Sprint Galaxy S III
    Last Post: 04-14-2014, 10:43 AM
  5. Battery $ indicator grey
    By snoozec in forum Samsung Galaxy Note 3 in Canada (Bell/Rogers/Telus)
    Last Post: 03-31-2014, 10:24 AM
