Results 1 to 6 of 6
    zeeliejm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy S3 LTE GT-I9305 with Android 4.3 does not have Edge option anymore
    Good day
    I came here hoping to get some help. I have upgraded my S3 to Android 4.3, but now under network Connections > more networks > Mobile Networks > Network Mode, I dont have the WCDMA /Edge (2G) only option anymore. The only options there now is:
    • 4G/3G/2G (auto connect)
    • 3G/2G (auto connect)
    • 3G only
    I need to set my phone to Edge only as that is all I need and to save battery. Can anyone help me please? My previous version had this setting.
    Regards
  2. #2
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: S3 LTE GT-I9305 with Android 4.3 does not have Edge option anymore
    Welcome to the forums!
    Your carrier may have removed that capability, in which case there's nothing that can be done.
    It's possible that the setting is just hidden, in which case an app like Advanced Signal Status http://market.android.com/details?id=com.cc.signalinfo may be of use (unfortunately this app requires root access to function).
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    zeeliejm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the reply. The only thing that changed was that I went from 4.1.2 to 4.3. Did it using Odin. So that is why I was wondering if it's like that on 4.3. Looking to go back to 4.1.2 for now.
  4. #4
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by zeeliejm View Post
    You'll want to be careful with that - Samsung included an enterprise feature called Knox in 4.3 which modifies the bootloader, making it difficult/impossible to revert to previous firmware.
    Why don't you just turn off mobile data when you're not using it?
    zeeliejm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, sing Whatsapp mostly and as I am out most of the day, I need Edge only, much less battery drain. But I really dont think its my carrier, which is Vodacom South Africa. It was all fine till I upgraded to 4.3 and I also used Odin to upgrade
  6. #6
    JudH's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GSDer View Post
    Why don't you just turn off mobile data when you're not using it.
    The OP wants to save battery life. Turning off data won't help. I have a very weak LTE signal at the house. Even with data off the phone will switch to the LTE signal if it can. It'll switch back to 3g a few minutes later only to switch again in minutes. That constant switching combined with running the transmit power up and down really messes with battery life. I picked up at least 30% maybe more disabling LTE.
    OP. Try the method here.
    https://forums.att.com/t5/Android-Di...f/td-p/3326169
    Google "Samsung disable lte" if that link fails. It describes a way to access the network mode by ejecting the sim card therefore bypassing carrier restrictions. I haven't found any other method that works on 4.3.
  1. SideSync not in Samsung store
    By Wahya in forum Android 4.4 KitKat
    Last Post: 06-10-2014, 08:39 AM
  2. Can't find San Disk 128GB card anymore?
    By deadp1xel in forum Samsung Galaxy S5 Accessories
    Last Post: 04-12-2014, 05:27 PM
  3. Knock on with nova
    By cootiesboy in forum LG G2
    Last Post: 03-31-2014, 05:50 PM
  4. Replies: 0
    Last Post: 03-30-2014, 10:55 PM
